Question about Altec Lansing Audio Players & Recorders
Regarding Altec Lansing BXR1121, what is the purpose of the third wire coming out of the Right Speaker, besides one wire going to the Centre Speaker and one wire going to the Left Speaker?
Anonymous
SOURCE:
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
Anonymous
  • 34 Answers
SOURCE: front left speaker is louder than the right one
JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
Posted on Oct 29, 2008
Alan Peterman
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
nitantsoni
nitantsoni
SOURCE: Altec Lansing ATP3 broken speaker wire ORANGE connector/jack.
Here you go
Posted on Aug 27, 2012
Power supply of multimedia speaker gets hot
Hot is a relative term, All electrical items get hot. Unless it gets so hot that you cannot touch it or it melts the case you are ok
Apr 15, 2016 | Altec Lansing bxr1121 2.1 channel speaker...
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
ALTEC Lansing BX1121 manual
I'm not sure if you put the right model but I found the info for the model BXR1121 on the following link: http://www.retrevo.com/support/Altec-Lansing-BXR1121-Speaker-Systems-manual/id/21327bh832/t/2/
I hope it helps.
Sep 20, 2010 | Audio Players & Recorders
The two speakers dont work.One of them does not
check the cable may be cable from first mall speaker problem
May 13, 2010 | Altec Lansing BXR1121 2 Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Finding replacement Power Supply for Altec Lansing
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
Feb 20, 2008 | Altec Lansing Multimedia Computer Speakers
How to repair atp3 altec lansing
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
60 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
