I have tried to shir fabric with elastic thread on my Pfaff 1475, by changing the bobbin tension. Also by changing the thread tension and stitch length. I've used the 2A foot to shir holding the elastic thread by hand as the machine sewes, but this is not the effect I wanted.
Not sure if this works on all machines, but I have used this method on many different models. You should not have to adjust the tension on the bobbin or the top thread. Wind the elastic on the bobbin by hand, not stretched as you wind it. Just normal, then try a test piece. The only thing that you should adjust is the stitch length if needed. The bobbin tension is a very tricky thing to meddle with. Hope this helps.
Testimonial: "Thank you Ruth. This works great."
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Thank you Ruth.
I tried this and it seems to work. Glad to do some projects now.
You are most welcome.
