The router is sending out a signal, but there is no internet through this! we have full signal, but cannot connect to the internet.
You don't indicate your configuration or model, but assuming that you have a high speed modem (like cable or DSL) what usually works is:
Shut down your computer, unplug the cable modem and the router from power (remove the connection from the adaptor on back, no need to go to the wall unless that is more accessible) . Connect
all three - computer to router, router to modem. Make sure that the
ethernet cable between the router and the modem is in the router uplink
port and that the computer is plugged into one of the four ports that
look alike. Wait 30 seconds - plug in the modem. Wait another 30
seconds, plug in the router, wait another 30 seconds and boot the
computer.
If this doesn't work, repost with what did happen. If you have a different configuration than I assumed, please post a clarification giving your actual configuration including model numbers.
SOURCE: My internet provider states my router is sending out signal
You will need to secure the wireless network so that other people will not be able to connect to your network?
Click Here to know how to secure the wireless network and other info
SOURCE: My linksys WRT150N router won't recieve internet
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
What kind of router? is the cable for the Internet plugged in the correct plug?
