Question about Casio Watches
Hello, my casio edifice 5117 does not doing hourly beep
Posted by zec michal on
Jojo
    Master:
  • 474 Answers
When you buy casio it comes with operating manuals you just have to set it "hourly beep" = and a symbol like that will appear.
Posted on Oct 02, 2018
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
Anonymous
SOURCE: setting the analog dials on the casio edifice EFA 120
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Go here to get the instruction manual
Posted on Oct 20, 2008
Anonymous
SOURCE: Casio Dual Time Illuminator - stop it beeping on the hour
Follow this link for a manual http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2481&submit.x=34&submit.y=9
Posted on Mar 31, 2009
Anonymous
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: Casio Edifice Chronograph Ef539d1avdf Gents Watch
mcdevito75 here, You can contact Casio at 800-706-2534 Optn. 2 for a new owner manual.
Posted on Jul 14, 2010
Casio edifice EF527D-1AV
Do you realize that this watch has a screw down crown to keep it waterproof?
Hold it in and turn it clockwise to lock it down.
Let me know if this helps.
Mar 11, 2014 | Casio Mens EF527D-1AV Edifice Stainless...
Please how do i set the hour and minute time on the Casio edifice wristwatch 2747 EFA-110
Hi,you need to look at the user manual..
just in case ,if you need to download a soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jan 27, 2011 | Casio Edifice EFA110D-1AV Wrist Watch
Hi, My Casio Edifice EQS-500C watch doesn't beep when I press "mode" button anymore. I did something wrong I guess when I was setting the time.
Hi as far as I know this watch model only beeps when you are configuring time and when you want to go back to time mode from any other one (chrono, world time or alarm mode) by pressing left lower buttom for a few seconds. It only beeps if you have set the alarm. It does not have light either. Hope this clarify.
Rafael
Dec 08, 2010 | Casio Watches
How to set my edifice EF528 manually, time setting, alarm ect...my uncle give me but eithout manual guide...it difficult for me to set all the functions.
Thank you for contacting Casio.<br /> You can download the manual direct from Casio. <br /> <a href="http://www.casio-europe.com/euro/watch/edifice/">http://www.casio-europe.com/euro/watch/edifice/</a><br /> Best regards.
Aug 25, 2010 | Casio Edifice EFA109-7AV Wrist Watch
I have casio Edifice E-546. The date changes at 12pm instead of 12am everyday. Can someone help/
mcdevito75 here, Many Casio Watch Models out there, I'll bet however your Casio is displaying say 1 AM rather than 1 PM as it should if the time is indeed PM after 12 noon, if so, this is why the date is changeing at 12 PM rather than, 12 AM simply re-set your casio and make sure the time of day is set at PM for time after 12 noon and AM for time anywhere before 12 NOON. Also, as you set your Casio, look for anything that may give the hint of Military time, this may be revilled as 12 hours or 24 hours, if you have anything like this, make sure it's set for 24 hours. If you have additional problems, visit a small watch repair shop in your area. Again there are many, many Casio models out there and without your watch with me it's difficult to be more accurate.
Jul 25, 2010 | Casio Edifice EFA110D-1AV Wrist Watch
Casio edifice mens watch user instructions needed because i can't turn of the alarm and it goes off at half 5 every morning please help
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
Sep 09, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Casio Edifice Watch
Here is a link to the manual: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1310.pdf It says: Hold do the (A) button [the upper-right button] to advance the analog time setting. The analog time will adjust forward at high speed. It only goes forward, so if you miss the proper time, you have to go all the way around again.
Mar 12, 2007 | Casio GW1310A-4AV Wrist Watch
Watches Logo
Top Casio Watches Experts
Bruce Robin
k24674
Resolution IT Dubai
Resolution IT Dubai
Are you a Casio Watch Expert? Answer questions, earn points and help others
