Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
TV began to have pink and blue hue on and off and staying on longer and more frequently. Not sure if lamps were knocked loose since 2 yr old ran up against tv. Also, timer/standby light is blinking even when off.
Posted by indiatita on
Anonymous
    Scholar:
  • 80 Answers
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Posted on Aug 08, 2009
Our Sony KP-53HS30 53" HD-Ready Rear Projection TV
According to the tech manual I looked at, it's a bad board - it just doesn't say which board. Sorry. Looks like it's making a trip to the shop.
Good luck.
Jul 06, 2011 | Sony KP-53HS30 53" Rear Projection...
My Sony KP-53HS30 rear projection tv looks like a 3d movie without the glasses. It comes and goes and sometimes will have red, green, blue squigley lines all over the picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 started with Pink and Blue picture and timer blink
You probably have one or more bad CRT's causing the problem. Due to the age of the set and cost of repair, I would not invest the money needed to repair the set properly. I would replace all three CRT's and the cost would run over 1000.00 up to 1300.00 .
With the cost of new sets today, you could replace it.
I hope this helps,
Skyassoc
Aug 05, 2009 | Sony KP-53HS30 53" Rear Projection...
Pink image on Sony KP-53HS30 TV
Pink? If this is a retangular box that appears then I would suggest to look into the fact that you have turned on "TEXT" mode within the "CC" closed caption settings.
Jul 23, 2009 | Sony KP-53HS30 53" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS30
sent the info to your email address
Mar 31, 2008 | Sony KP-53HS30 53" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
376 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
