SOURCE: error code on the electronic
Error code F2-E0 is for a shorted touch pad. Get more info on appliance parts and error codes.
SOURCE: range flashing code f2eo
F2 - E0
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
F2 - E1
Keypad cable unplugged
F2 - E5
Cancel key drive line open
F2 - E6
SOURCE: kitchen aid stove oven shutting off reading error
Electronic range clock failure. You will need to replace this part. It is located where your keypad is. You will need to get behind it and pull the part out and replace it with the exact kind from repairclinic.com
SOURCE: kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
sensor or oven temperature sensor fuse opened
Replace oven
temperature sensor or fuse
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
F3
Thanks
