Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
The drain behind the panel at the rear of your freezer is most likely plugged with ice. The easy fix would be to transplant your freezer goods to another freezer, unplug the fridge and leave the freezer door open overnight.
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Pull down slightly on the bottom bin lip , and pull the bin foreward . The bin has to lock in place , or it would slide foreward , each time the ice dispensor is used , causing the freezer door to be pushed open from the force .
Hi , let the freezer incline put pieces of thick cartoon on front legs of the freezer so that the door will shut , the door contact magnet are weak. check also the screw and bolts of the door might lose.
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
