Has the battery ever been replaced? It may only need a new battery. When the battery has been replaced it will need to be 'synched' to the central locking. A few links to help you -
Key fob not working
How To Replace Land Rover Freelander Key Fob Battery 2002 2003 2004 2005
SOURCE: how do i reprogram my02 ford focus remote locking key fob please.
get in your car close door hit the unlock button then put key in the ignition cycle the key from off to on (STOP BEFORE START POSITION) cycle key off to on 7 times after the 7th trime the doors should lock the unlock automatically that means u are in trainning mode hit the unlock button on key fob. the key fob should now work if it doesn't then try changing batt
SOURCE: 2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
SOURCE: Central locking issue on my Land Rover Discovery II 2003
Does it open from the outside once you have manually opened it from the inside.
SOURCE: remote control for land rover freelander not
Replace the battery in the key unit. There is a slot on the bottom edge for a coin or screwdriver to twist it open. Open, replace battery and snap shut.
Please rate this answer. Thank you.
