Question about Furniture
My osim 760 massage chair got error code: 12?
Posted by ramsey james... on
4 Related Answers
Anonymous
SOURCE: where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
Posted on Jan 23, 2015
magna buff
  • 3828 Answers
SOURCE: osim imedic 500 chair controller only displays: er how to fix?
massage chair
er is "error message" .....not much help
lots of components that can fail on a masage chair
look for the user manual
Posted on Jan 22, 2017
easymassagec
Derek James
SOURCE: What is the difference between a Swedish massage chair and a Shiatsu massage chair?
Swedish massage is common massage therapy that involves long and soft kneading strokes in a rhythmic and light manner. The Swedish massage chairs have basically five moves which are as follows: The effleurage, petrissage, friction, tapotement and vibration.
Shiatsu massage is a Japanese technique which denotes finger pressure. The shiatsu massage chairs integrate erratic rhythmic pressure on the required parts of the body which could also be termed as the acupressure points.
http://www.easymassagechair.com
Posted on Nov 23, 2017
25526839nwu
Heward Mahlasela
SOURCE: Move my OSIM uComfort chair
  1. Locate arm brackets underneath the seat pan. Unscrew the plastic tri knob until it is loose
  2. With Allen key screw the locking bolt from the threading hole until it disengages.
  3. With a Philip screw driver or a screw gun unscrew the four (4) bolts on attaching the mechanism to the seat pan.
  4. With a Philips screw driver or a screw gun unscrew the four bolts (4) on attaching the two (2) arm width plates to the seat pan.
  5. The arm pad can be removed from the arm bracket by screwing the two (2) bolts under the arm pad. This can be performed with a Philips screw driver.
Posted on Dec 02, 2017
Manuel for imedic 530
Support
Web link above to OSIM states:
Q: What should I do when my OSIM massage chair is having problem? You can refer to the Operation Manual for the possible causes and trouble-shoot actions. If the problem persists, please contact us at [email protected] with description and pictures of the issue (if possible) that we can identify the problem and solution right away. Kindly also include your phone number and location in the email that our technical department will contact you as soon as possible to arrange in-house repair.
Feb 25, 2018 | Computers & Internet
Osim imedic 500 chair controller only displays: er how to fix?
massage chair
Jan 22, 2017 | Health & Beauty
How to fix the ERROR 02 on a OSIM UDivine S massage chair?
Error 2 is updown motor sensor is not working. Replace sensor. Will ok.
Jun 07, 2016 | Furniture
Where can i find the fuse?
What Can Break in a Massage Chair? - Elite Massage Chairs
https://www.elitemassagechairs.com/what-can-break-in-a-massage-chair/
So believe it or not, the most common problems in a massage chair - about 90% of ...but it's not always easy depending on the design of the chair to find the fuse that ...This is the electric motor that moves the footrest up and down in a smooth ...
power outlets fuse location Electric Massaging Chairs ...
www.fixya.com > Forum > Tags > power outlets fuse location
Electric Massaging Chairs power outlets fuse location questions and answers. ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product ...Where can I purchase a plug in outlet chord (power chord) for the osim ...
electrical fuse blown Electric Massaging Chairs Questions ...
www.fixya.com > Forum > Tags > electrical fuse blown
Electric Massaging Chairs electrical fuse blown questions and answers. ... In short does anyone know where I can get a circuit board for this chair? ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product manual: ...
radio ht Electric Massaging Chairs Questions & Answers ...
www.fixya.com > Forum > Tags > radio ht
Electric Massaging Chairs radio ht questions and answers. Ask your radio ht electric massaging chair questions. Get free ... Do you know where I can find fuses?
Amazon.com: Electric Full Body Shiatsu Massage Chair ...
Dec 14, 2015 | Furniture
Where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
Jan 23, 2015 | Furniture
Osim ucomfort remote control not working
Unfortunately, we can't help help here either. We can, however, give you advice on how to resolve problems with you Mac laptop in this section.
Nov 22, 2013 | Brookstone Massage Chair: Pre-Owned OSIM...
Osim massage chair not working; er message
Hey, I faced the same problem with OSIM massage chair and after contacting a local repair guy I was disappointed as he wasn't able to repair it. Then I contact OSIM support as my massage chair had a pending warranty of 8 months, they took some time(8 days) but they repair it very well, now it's more than 3 years and I'm still using it without any problem.
Source: https://www.relaxthatbody.com/massage-chair-reviews/
Feb 08, 2013 | Furniture
Furniture Logo
256 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
