Since it works on your PC it's not a problem with Netflix. You probably have to update the Netflix app on your SmartTV
https://help.netflix.com/en/node/100153
SOURCE: No video when trying to watch netflix on xbox.
Have you gone to My Xbox, System Settings, and selected the appropriate high definition video setting? Do you have it set up on your TV as well? Both need to be set for HDMI.
SOURCE: I have DELL color laser printer 2130cn error msg load SSF ??
Its not a printer problem more of the paper source of that document is selected as SSF. So in most programs go FILE>PAGE SETUP. Select the paper tab and make sure the correct tray settings is selected. I.E "Default tray" instead of "SSF". cLICK "Default" at the bottom to make this the standard document settings and the problem shouldn't crop up again.
SOURCE: "No signal" on hdtv while trying to watch netflix via xbox
First you need to eliminate the possibility that
the box is loosing video feed from the G.P.U.
hook the unit up in with normal yellow
white and red a/v connection for standard TV
out . if it happens shut the unit off and on again
and if you have sound and no video it's the G.P.U
becoming disconnect , the fix for this is to have
the chip re-flowed back to the P.C.board .the other
cause is a failing HDMI cable but im guessing you
already replaced that.
If you have any questions feel free to ask
Rob
Testimonial: "Very helpful"
SOURCE: I get "content error" when
manually update your tv's software. download it from sony.com/support
SOURCE: Content error when trying to
update your tv manually. you can download the software update from esupport.sony.com
