Question about Nakamichi Televison & Video
Hello I have a vinatge nakamichi CR-4 that has a recording lights still on problem with it when it not supposed to be on when it powers up.
What its doing is that both the L/R channels should be out when it powers up but never on at all before recording any tapes. Any suggestions to this would be appreciated.
Posted by John Jusko on
3 Related Answers
Anonymous
  • 15 Answers
SOURCE: VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Posted on Feb 05, 2008
Michael Borelli
  • 979 Answers
SOURCE: Picture flips whill playing tape recorded from cable TV station
All tapes do this, or only ones made on this machine?...accordianman
Posted on Feb 15, 2008
Rob Galayda
  • 54 Answers
SOURCE: Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
Posted on May 09, 2008
Nakamichi delta 50B remote not working have put new batteries in no light showing where do I get a new remote please
I found a site that sells genuine Nakamichi remotes but please check that this listing will be suitable for you before placing an order (says suitable for 100R and 50) -
NAKAMICHI DELTA 100R replacement remote control
How do you repair a vintage nakamichi cassette tape deck?
only if you find an electronics professional that likes to fix old gear
otherwise junk it
2answers
HI EVERYONE I HAVE A NAKAMICHI SOUNDSPACE 12 ,UNFORTUNATELY ALL OF DICS TRAYS ARE NOT WORKING.WHERE CAN I FIX IT AND WHAT ARE MODELS OF OPTICAL LASER LENS CAN REPLACE FOR MY SYSTEM? THANKS
Tks so much, everything is OK because main unit and deck unit are working well but all optical laser lens are broken.What kind of model of optical laser lens that I can replace for my system ?
Best Regards
1helpful
Is there a remote for nakamichi sr2a
no remote,https://www.manualslib.com/manual/1014772/Nakamichi-Sr-2a.html?page=4#manual
Going on standbymode and power green light blinking TA4 nakamachi
I'm not familiar with this product, and there the best I offer is that you consult the user guide (which you probably already have)
http://www.ps2netdrivers.net/manual/nakamichi.ta-4/#manual
or (buy) a service manual (which it seems includes a troubleshooting guide) from any of a number places, two are given below:
http://www.manualszone.com/en/nakamichi-service-manuals/62888-NAKAMICHI-TA4-service-manual.html
and
http://www.nakamichi.owner-manuals.com/TA4-service-manual-NAKAMICHI.html
All three manuals/guides are available from
http://www.hifiengine.com/manual_library/nakamichi/ta-4.shtml
There other websites where you an download the service manual (I don't know if the are the 'official' service manual, or different ones that have been written by different people).
If you are really stuck contact Nakamichi through www.nakamichi.com or (what appears to be a more friendly site) http://www.nakamichi.co.uk/support
24.August.2014
2answers
Televison & Video Logo
Top Nakamichi Televison & Video Experts
ray gallant
Tom Chichester
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
