Question about Vulcan Heating & Cooling
Our vulcan wall heater when trying to start when we release the button the flame goes out.
Posted by Mary Szybkowski on
Steve F
  • 1,360 Answers
The thermocouple which senses the flame has probably failed or it could be a poor pilot flame (Dirty or partially blocked injector) Get a licensed gas Tech to service it if this hasn't been done previously.
Posted on Oct 01, 2018
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Posted on Sep 27, 2008
Papa0106
  • 13 Answers
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Posted on Feb 28, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Posted on Dec 24, 2009
mxc2
Marc Powers
  • 146 Answers
SOURCE: My all-pro propane heater will not stay lit for
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Posted on Jan 05, 2011
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: can't light a vulcan heritage
Hi and welcome to FixYa, I am Kelly.
What you are experiencing is the lack of a signal from the thermocouple to the gas valve. I.e. the thermocouple is not passing heat information at all. This is caused by either a defective thermocouple, a dirty mating area where the thermocouple connects to the gas valve or... an improperly positioned thermocouple that is not "in the flame" with the pilot lit.
  • First make sure the FIRE end of the thermocouple is in the flame when lit. (reposition if necessay)
  • Next disconnect the thermocouple by unscrewing the fitting on the top of the gas valve. (No gas will come out) Clean the metal mating area as best you can and then re-install the thermocouple. Just a good snug fit. Once you feel it come snug add 15 degrees of tightening motion with a wrench.
Attempt to light the pilot... wait 45 seconds to 1 minute while holding the pilot button down before letting it up. If it stays lit.... GOOD JOB. If it goes out the next step is to replace the thermocouple. If after replacing the thermocouple it does not stay lit the remedy is to replace the gas valve. There are no short cuts and the sequence of repairs is just as I stated in order.
You can remove your old thermocouple and walk in to almost any appliance parts supply or Plumbing and heating supply to purchase the correct thermocouple without a part number. They will match it up with yours.
Thanks for choosing FixYa,
Kelly
Posted on Feb 20, 2011
How can we get the pilot light to remain on a Vulcan gas Space heater ? It lights, but as soon as we release the button it goes out again.? Have tried many times without success. Can anyone help with a...
Make sure the pilot flame is hitting the thermo couple . If it's not, you,LL have to clean pilot burner, but if it is hitting it,then you'll have to replace the thermocouple. Cost about 35$. I hope this helps
Sep 27, 2017 | Heating & Cooling
Procom ML 300TBA Pilot will not stay on when button released
It sounds like you need to clean the contact on the thermocouple.
Here is a link to the service instruction of how to do that.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 12, 2012 | Procom ML300TBA Heater
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
When I push the setting dial down and push the iginator control button the flame starts, and when I release the dial knob the flame goes out and that is on Model # CBN 301 DESA Blue Flame Custom Glow
It sounds like your thermocouple either needs to be cleaned or replaced.
I would start by cleaning the thermocouple first.
Here is a link to the instructions.
Oct 17, 2011 | Desa International Blower Glow Warm Wall...
Trouble starting an vulcan oil heater
Are you able to post a picture/photo of the heater. I may be able to give lighting instruction.
where are you, I'm in Adelaide SA
Oct 25, 2017 | Vulcan AUW230A Heater
When I light the pilot and release the know the flame goes out
1. Try holding the knob longer
2. Locate & clean the sensor, a tube that's sticking into the pilot flame. Use a green scotch-brite or steel wool then wipe with a damp paper towel.
Dec 18, 2010 | Desa International Blower Glow Warm Wall...
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
Pilot Light won't stay lit on wall furance
The low voltage wiring and the thermostat has noting to do with the pilot function of the wall furnace, check to see if when you have the pilot lit manually, while holding the button in does the flame impinge on the thermocouple and does the flame try to wrap around the thermocouple? if not the thermocouple and pilot flame need to be adjusted so that it impinges on the TC, if it does have a good flame impingment, then you probably have a bad TC from the factory, call them and have them send you a new one if still under warrenty.
Jan 20, 2009 | Williams 1403622 Gas Compact Heater
Heating & Cooling Logo
47 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
