Question about Andis Health & Beauty
I was wondering how to attach the black and white leads on an andis clipper
Posted by Lisa Grant on
5 Related Answers
Anonymous
  • 61 Answers
SOURCE: loud andis master clipper
adjust power screw in one quarter turn
Posted on Jan 26, 2009
Anonymous
  • 228 Answers
SOURCE: Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Posted on Jul 20, 2009
Anonymous
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
philschneide
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: when i cut hair my andis master clipper seems to
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Posted on Jun 23, 2010
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Feb 04, 2014 | Andis AGC2 Hair Trimmer
I need to take apart my andis master clipper to see what part i need to order i need the manual take apart the clipper
Stop, Their no manual on how to take your Andis Master apart. The Andis Master has small parts that you can lose. The adjustment on this clipper are not easy to do. I
Feb 11, 2011 | Andis Master 01557 Hair Trimmer
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Mar 18, 2010 | Andis AGC2 Hair Trimmer
Inside black wire is not connected to anything and neither is the white wire
Contact [email protected] they will help with this, they are good and know about clippers.
Mar 12, 2010 | Andis 04603 Hair Trimmer
Aug 13, 2009 | Andis Health & Beauty
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
Health & Beauty Logo
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
