Question about Samsung Office Equipment & Supplies
Samsung printer imaging unit failure, how can it be solve?and how to fix it?
Posted by mitieli waqalevu on
Jessica Michael
    Master:
  • Samsung Master
  • 459 Answers
The error indicates that you have not installed the imaging unit. If you have installed it already, uninstall and reinstall the imaging unit.
Open the front cover of your Samsung printer and locate the imaging unit, it will be present at the bottom, below the toner cartridges.
A small black plastic with copper terminals will be present at the front of the imaging unit.
Remove the Fuse Housing. A 200-ohm resistor and an option 50-ohm resistor will be available.
Remove the blown fuse resistor, if applicable. Else, replace the 56-ohm resistor.
Place the 56-ohm resistor on the 200-ohm resistor. Now, place the fuse housing back, power On the printer, after the reset process the red light will go out.
If the issue is not solved, make sure the new and the old resistors are having proper contact with each other.
Ensure you are using the correct value of the resistor.
Turn Off and On the printer. For Support Call our Toll-Free 1-866-293-9220
Posted on Oct 09, 2018
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
Change imaging
Posted on Oct 03, 2018
I have samsung C430W printer..I replace the transfer imaging unit but still it showing to replace it..how can I reset the page count of transfer imaging unit...please help...
1, I have samsung C430W printer..I replace the transfer imaging unit but still it showing to replace it..how can I reset the page count of transfer imaging unit...please help...
2, Turn Off the Samsung C430W printer using its Power button or disconnect the power cord from the back of the device and also from the wall outlet. Else, turn Off the switch present near the socket. Wait for about a minute. Replug the cord between the printer and the outlet. Power On the device and verify if the problem is solved.
3, To reset the page count, Click the Reset Fuser Life button and then choose the OK button, this resets the fuser. If the error is not rectified, the imaging unit has to be reinstalled or replace it with a new one again.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Oct 09, 2018 | Samsung Office Equipment & Supplies
Samsung CLX-3160FN problem with faded black images/text only
Many of today's printers have a "toner save" option, which makes the black appear lighter, and I'm pretty sure this isn't your problem. However, I wanted to rule-out the obvious first, which is just a setting.
If you're seeing the black lighter in vertical "stripes" or segments in your printing, then it's most likely due to a dirty toner cartridge (but you said you replaced it), or cleaning the LSU inside the unit (as it says in the owners manual).
Just in case you don't have the manual handy, here's an online link to it:http://downloadcenter.samsung.com/content/UM/200611/20061122152910875_CLX-3160_English.pdf
I hope this helps!
Feb 13, 2012 | Samsung CLX 3160fn All-In-One Printer
Cloudy images and carts not clear while printing
If your printer prints like this,
slamfix_21.jpg If The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 30, 2010 | Samsung CLP 300 Laser Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
My samsung clp-315w prints smudgy black lines
Cleaning my unit resulted in the solution of this problem. I removed the toner cartridges, the imaging unit, and the waste bin, opened the back door as well, and blew it out with "canned air". This will not solve all problems, but it is the right place to start. be careful to keep the imaging unit out of bright light when you you have it out of the printer.
Dec 06, 2009 | Samsung CLP 315 Laser Printer
How do i fix a transfer belt error on my samsung 3160? where is the transfer belt?
take out the imaging unit(imaging unit is where the toners are put and a green OPC is there).
First open the front cover.
then pull the imaging unit.
after that there will be a delicate transfer belt.
Aug 17, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Apr 04, 2009 | Samsung CLP 300 Laser Printer
"REPLACE IMAGING UNIT SOON" on my Samsung printer
there is no other option except this as this is the common problem in this types of printer and the company has not left any other option except this.that is to replace the imaging unit.
thanks.
Dec 12, 2008 | Samsung CLP 300 Laser Printer
Imaging unit
Is it a genuine Samsung Imaging Unit? The unit is not seeing it as such.
This is the # for it, CLP-R300A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 08, 2008 | Samsung CLX-2160N All-In-One Printer
349 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
