Microwave Ovens Logo
R
Reg Ralph Posted on Sep 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a 1.1 size microwave. I tried popping a full size bag of popcorn using 2 pushes of the popcorn setting. The bottom popcorn came out black. Any idea why?
Ancient god of gaming
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 439 Answers
  • Posted on Sep 30, 2018
Master
Level 3:
Dedicated:
Answers
439
Questions
Helped
191387
Points
2012
The microwave burnt it. It will be a bit of trial and error with using your new microwave and will also depend (in this case) the brand of pop corn you've cooking. Check the recommendations on the pop corn packaging for time and heat range. Happy popping!
Jason Alden
Level 2:
Habit-Forming:
New Friend:
  • Expert 61 Answers
  • Posted on Oct 11, 2018
Jason Alden
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
61
Questions
0
Helped
9818
Points
270
The microwave burn it. The packaging of popcorn brand is low quality, That's why is burn it. You try a must change the brand of the popcorn and check the recommendations on the popcorn packaging for time and heat range of the product.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 16, 2008
SOURCE: Will not pop popcorn without burning it
use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Anonymous
  • 9 Answers
  • Posted on May 12, 2008
SOURCE: bright flash inside microwave
try a different brand of popcorn & let me no what happens
Anonymous
  • Posted on Dec 13, 2008
SOURCE: Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 26, 2009
SOURCE: PAINT DAMAGE INSIDE MICROWAVE CAVITY.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If it's allowed to stay that way, it can arc, which will greatly accelerate the charring & rusting processes.
popcornhelp
  • 6 Answers
  • Posted on Jun 01, 2009
SOURCE: viking professional vmoc205ss convection Cooking POPCORN
You need to use one of the metal racks that came with the Viking microwave to raise the popcorn bag off the bottom of the microwave. It works great!
2answers
Microwave doesn't popcorn all the way on popcorn seeting
Most M/W use an estimated setting based on ounces of corn. I've found that many do not tell you how much is in each bag. The bags usually have no size markings. Check the face of the box for something like "2 each 3 oz bags".
* Try to use a normal re-heat setting (at full power) and cook a bag using the a minute longer than the recommended setting. Listen to the popping sounds and stop the M/W when the pops slow to 3-4 seconds. (2-3 seconds with 'Kettle' corn) Note the time lapsed and this is your correct setting. You may try the popcorn menu to find a similar setting but really your best bet is to use the method above as it's the most accurate.
* Note; Old or stale corn will not all pop (it dries out as it gets older and there is not enough moisture in the kernnal to steam pop.)
* M/W varies from model to model and brand to brand. Only way to check is to try several settings to get the best results.
* Pop corn brands vary in quality. You will find the better name brands pop more.
* Once you find a good popping brand then stick to that size and brand. (unless they change it on you.)
* If your really stuck on getting every corn kern popped then go with an air popper. It won't come out of cooker till it pops.
Good movie, don't forget the goobers, milk duds, frosty...
Aloha, ukeboy57
2helpful
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
We can't get our microwave to fully pop the bag of popcorn. If we use the popcorn button it stops before the bag even starts popping. If we preset the time, the same occurs and if we run it until its...
Always place the bag of popcorn on an upside-down paper plate.
This allows more microwaves to penetrate the bag from the bottom.
Also always place food of any kind in the microwave off-center on the tray, NOT in the middle of the tray.
Not only does it cook more evenly (think of how you stir liquid) but it also prevent the same spot from being heated repeatedly on the glass turntable, which can lead to overheating and breakage.
1helpful
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
1helpful
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
I tried poping some popcorn in a brown paper bag and it caught on fire. I tried to the microwave again after i put the fire out and cleaned the mess up but nothing is working at all. No breakers were...
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
5helpful
Viking professional vmoc205ss convection Cooking POPCORN
9helpful
4answers
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
