Question about Dirt Devil Vacuums
Where is the reset button for the dirt devil breeze vaacumn
Posted by Nancy Maitland on
Thatvacguy.com
  • Dirt Devil Master
  • 1,604 Answers
It doesn't have one
Posted on Oct 23, 2018
5 Related Answers
Anonymous
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
Robert Pagliaroli
  • 294 Answers
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 24, 2009
galati2k
PETE GALATI
  • 281 Answers
SOURCE: i cant get the power brush to work
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Posted on Apr 08, 2009
galati2k
PETE GALATI
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
Anonymous
  • 50 Answers
SOURCE: how to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Posted on Apr 09, 2010
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Why does the belt keeps comming off
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Apr 28, 2014 | Dirt Devil Breeze Bagged Upright
Why does the dirt devil breeze turbo shuts off
Hi there! The vacuum is equipped with a thermal protector sensor that will automatically shut the motor down if it reaches a certain temperature. This is usually caused by either a clog or a filter that needs to be cleaned or replaced. Make sure you check both the hoses for clogs and clean all filters properly. If a filter is really dirty it may be time to replace it. Hope this was helpful!
Apr 24, 2014 | Dirt Devil Vacuums
My dirt devil breeze was rattling while on. I found that the one end of the brush roller had shifted off the sqaure ends. Is it bent inside? Can it be repaired or do I need a new brush roller
The ends are fastened to each end of a shaft that passes through the roller. If the brush has shifted, perhaps the nuts or other fasteners have loosened. You can try to tighten the nuts but be carefaul to avoid tightening too much, causing the roller to not turn freely
Sep 28, 2012 | Dirt Devil Breeze Bagless VacuumVacuum
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
How to put the belt on the deit devil breeze
Apr 09, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Vacuums Logo
189 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
kltcoco
Level 1 Expert
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
