SOURCE: My Sportcraft Treadmill has an error code 7 and
Try this website http://www.howtomendit.com/answers.php?id=102798. It got mine running. I haven't had time to test it to see if it is a permanent fix, but it's running...
SOURCE: Where can I find a replacement sensor wheel for a
Try Icon Service Group. You can google them and find the web address. They are an excercise equipment warranty provider but will also see you parts.
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
SOURCE: i have a sportcraft treadmill tx335 it shows error
Error code seven is due to the console getting locked. I called Sportcraft and they said to do this: Unplug the treadmill for five min and then re-plug the treadmill. Now push the ON/OFF switch to ON and insert the safety key. Now press the MODE and STOP button simultaneously. Without releasing the buttons take out the safety key and insert it again. Now you should hear a beep and the display will come on. Release MODE & STOP and now press the Speed increment (+) button
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
