M
Micheljanecek Posted on Sep 30, 2018
I need the code corresponding for a Bose cinemate2 thank you
jimboy
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 30, 2018
jimboy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
355
Points
12
How to get the code for ecoin
2 Related Answers
Anonymous
  • Posted on Feb 20, 2010
SOURCE: Can't program Dish Remote to work with bose cinemate2
have AOC and need code
Lawrence Oravetz
  • 10558 Answers
  • Posted on Mar 31, 2018
SOURCE: can i use my cell phone as a remote for my bose cinemate2 surround sound
If Bose has an app to do that you can. I have the Roku app that allows that, so check Bose's website for an app.
Can i use my cell phone as a remote for my bose cinemate2 surround sound
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 • Bose SA3
4helpful
2answers
I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
My 722 wont program to operate my BOSE GS Series II.
russ063
761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780
I have provided the codes and instructions on how to program your DISH remote to your Bose receiver. I hope this helps.
Remote codes:761 and 780
Instructions on programming:
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    1. Press and hold the desired Mode button until all mode button backlights come on, then release.
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Note: The light will blink off after each digit is entered and then return to a steady light.
    3. Press the POUND (#) button.
      If the code entered is valid for the remote, the mode light flashes three times.
Ray Calo
DISH Network
Do not have remote for bose cinemate speaker system. How can I program universal remote for dish network remote control?
It would be our pleasure to help you with that.
Here are some steps that will help in addressing your DISH Network remote toyour Bose Home Theater System:
1. Press and hold the desired Mode button until all mode button back lightscome on, then release.
2. Use the number buttons to enter the device code corresponding to theequipment. AUX Mode: Before entering the device code:
  • Press 0 for a TV
Codes for Bose Amplifier: 656, 761, 639.
3. Press the pound (#) button Note: The light will blink off after each digitis entered and then return to a steady light.
4. Press the POUND (#) button. If the code entered is valid for the remote, the mode lightflashes three times.
Although we are sure this will help, we cannot guarantee that it will work for your particular make and model.
Thanks for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
I connected a non-powered subwoofer, but it is not responding. I have got bose speaker system accoustimas 10. [email protected]
hi,
u can connect the bose to ur receiver. connect all speaker output of or receiver to bose corresponding input. and the sub line to sub pre out. for any further assistance can contact through fixya.
ok
2helpful
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
2helpful
How to connect multiple video sources
Bose makes a product called a VS-2 video enhancer. All it is is a video scaler and switcher, which, if I remember correctly, has 3 composite in, 3 component in, and 2 HDMI in, with 1 HDMI out, among other connections. It sync's with your Lifestyle system to pick the correct video input when you pick the audio input that corresponds. I can't seem to find it on the Bose website, although I did find the below link. The piece is probably discontinued, but I'm sure Bose or your local dealer can get a hold of one.
http://www.bose.com/flash/home_entertainment/accessories/vs2/video_player_vs2.html
2answers
Unlock 1997 Bonneville SSEI Stereo
If you can get me the factory code I can get you the unlock code
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
