Question about Curtis Televison & Video
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://homenol.blogspot.com/
http://electro-medical.blogspot.com//
Posted on Sep 30, 2018
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
SOURCE: i have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Posted on May 13, 2009
SOURCE: no sound on tv when laptop connected via hdmi
if you are running windows xp or linus i may not be able to help altought the problem might be solved in almoust the same way. For windows vista right click on the volume icon in the system tray icons and choose playback devices select HDMI output ( for 5920G is "Realtek HDMI Output" ) then press the "Set Default" button. The other way around is to go in the Control Pannel in the "Hardware and sound" cthegory and select sount than seth the default output to Realtek HDMI Output in the "Control Pannel Home" view, or in Classic view click/doubble click on "Sound" icon ( a speaker ) and do the same. In windows XP there is a similar approach. In linux go to System ->> Administration ->> Soundcard Detection and you should find a setting equivalent to the one in Windows
Posted on May 29, 2009
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
