Check the settings in the fire stick. Make sure it is set to DHCP. Or you may have to enter the wifi IP Address manually. If your wifi uses 192.168.1.1 as a starting IP address then enter 192.168.1.49 change the last 2 digits if already in use. Subnet. 255.255.255.0, Gateway 192.168.1.1.
if it uses 192.168.0.1 then change the 3rd set of numbers to 0. I.e. 192.168.0.49 gateway 192.168.0.1 same subnet.
SOURCE: Connects then disconnects.....PLEASE HELP!!!
Every time you click repair on windows the ip address of your network card is changed from your originally set one to something similair to 194.168.x.x, obviously your router will not see your pc after this. You need to connect to your router via an RJ45 lan cable to ensure it is set up properly and enter the settings menu and make sure dhcp is enabled to give the pc an automatic ip address and check that the time out is set at zero, also check your MTU, it should be set at 1493 or 1500, obviously make sure your network card is set to obtain an ip address in the TCP/IP properties. just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 6, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed. Lastly if you have the software that came with the wireless card, dissable it by right clicking the pc network icons in your taskbar and click on enable WZC (Wireless Zero Configuration), as this is a more stable connection to your router and its transfer speed.
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
SOURCE: wifi connection problem
last time i too had the same problem where i had the Wifi connection lasting only for 5-6 minutes. and lately i discovered that my anti-virus component that i used previously (AVG)has blocked some of the settings which was expired and i got Avast and installed it.. thats when i found that my wifi connection started working fine. may be the same case for you as the problem seems same.. check it out. Regards
SOURCE: archos 5 wifi connecting problems
"hi have an archos 5, when trying to connect to wifi, keep getting "wifi error .(0)" or "wifi error .(21), i know i am in a wifi network area as my laptop and palm pda can connect ok, however the archos seems to keep scanning for networks until it eventually switches off, any suggestions would be greatly appreciated"
i have the same problem...PLEASE is there ANYONE who knows how to solve this issue.. my email is [email protected] i need desperate help..
thankyou
