You may need to get the sewing machine serviced; the repair must be handled as if you are fixing a computer. The F05/F5 error indicates a problem with the timing shutter, the PCB board or the wiring between them.
If you are going to try this, first unplug the machine and check the wiring. Next clean the timing shutter if the wiring is undamaged. Replace the timing shutter if the error recurs. If the machine still gives the F05 error, the PCB board has to be replaced.
Some of the parts for the Brother LB6800 are here: https://www.sewingpartsonline.com/brother-lb6800-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=157.
I hope this helps.
SOURCE: instruction manual for the dressmaker 6800
goto ifixmachines.com they have your manual, just email them if you don't see it
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
SOURCE: What is the Brother Pacesetter NX-200 F4 machine error, and how do I fix it?
You will receive F4 error message, when there is a problem within the unit, internal circuit board.
Your Brother Sewing machine need to be service.
Good Luck.
SOURCE: Free Brother sewing machine manual
http://www.brothersewingmachines.gur.co.uk/brother_ls_2125-5408
The above is a link to manuals for your machine. Look under the manuals tab for PDF files to download.
