Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
SOURCE: I have a 32
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
SOURCE: dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
SOURCE: turn on TV insignia 26 inch DVD combo. Screen is
Your TV will likely require repairs for this issue to be resolved. Service can be obtained by carrying the unit in to the place of purchase.
SOURCE: My AKAI tv/dvd combo - DVD quit working.
Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
good luck
Rich
