Question about Cell Phones
How do I remove the voicemail number - Cell Phones
Posted by Vikki McKay on
Elena Gillbert
  • 4 Answers
Hi....
To delete voicemail on Android devices, you can easily follow the below steps: - Follow the path of Settings > Application manager > Call Settings. - Then scroll down to the bottom to reach the Voicemail app. - Tap on it and then hit the Clear data option to continue the process.
you can take the more information then click here <a rel='nofollow' href="https://klantenservicenederland.co/microsoft/">Microsoft Telefoonnummer</a>
Posted on Jun 30, 2020
haley brown
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Omdat het een zeer goed en nuttig apparaat is en goedkoop in prijs en ook betrouwbaar. Canon Support-service is zelfs ook goed en de meeste mensen waarderen het vanuit hun hart.Click here: https://technischeondersteuning.blogspot.com/2020/06/hoe-kan-ik-de-canon-pixma-mg2522.html
Posted on Jun 16, 2020
Jimmy Jell
    New Friend:
    Welcome Back:
  • 5 Answers
  1. Open the dial pad on the device.
  2. Dial Voicemail. Tapping the number 1 and then hitting the green phone icon at the bottom should call Voicemail.
  3. Enter a password (if there is one). Enter the password for the voicemail by tapping the number keys and then the # sign.
  4. Skip through messages. There may be multiple voicemail messages on the account. Press 9 when listening to each message to save it and move to the next one.
  5. Delete a voicemail. Press 7 on any voicemail to delete them.
If you want any information contact with hp printer support number 1 800 712 0802 HP Printer Support Phone Number HP Technical Support
Posted on Sep 29, 2018
I have a samsung galaxy s7 edge but the voicemail number has been deleted by mistake. How can i get it back?
Hello, Lynne -
The voicemail number is one from your cell phone service provider.
You will need to contact your cell phone service provider to find out the voicemail number.
On my cell phone, with the Menu through the Messaging option, I can choose Voicemail and call my voicemail number. When I do, the number displays on my screen.
Jan 17, 2018 | Samsung Cell Phones
Wrong voicemail number
Call your services of the number company you have(like T-mobile).
And they will help you with that problem.
Mar 07, 2014 | Samsung Galaxy Reverb
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My dad is using my old enV. whenever he wants to check his voicemail it calls my number. How can i fix this?
You need to change his Voicemail number. On a Nokia this is fixed by going to your Tools/Settings and selecting Voicemail, and changing the Voicemail number there. You can get your dad's Voicemail number by calling up the customercare. But if you remove your number from the assigned Voicemail number, it should fix your problem.
May 18, 2010 | LG enV VX9900 Cellular Phone
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Where is the voice record key?
Voicemail
Your network stores the voicemail messages you receive. To listen to your messages, call your voicemail number.
Note: Your service provider may give you additional information about using voicemail.
The phone calls your voicemail phone number. If no
voicemail number is stored, your phone prompts you to
store a number
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 22, 2009 | Motorola Mobility RAZR V3
Sony ericsson t280i
You will have to call your voicemail number (network specific) and delete voicemails from there, not from your phone.
Oct 23, 2008 | Cell Phones
Voicemail
It is usually under message menu. try under setting of this menu. Alternatively you can use one more method that will sound funny but works. Press and hold the No. 1 key and see which number it is dialing. If the voicemail is already set it will be shown to you, edit this from the phonebook to your desired number. If the Voicemail has not already been set you will be prompted to enter you the voicemail number. Fill in the desired number there.
Feb 06, 2008 | Sony Ericsson K510i Cellular Phone
Deleted my voicemail key
Use the super key again to program a speed dial key that dials the voicemails number. Instead of selecting 'clear' slect "change" and type in the number. To find the number of the voicemail, go to another phone and press their voicemail key and watch the display. It may briefly display the voicemial group number. You also can dial the voicemail number without the use of a button on your phone. But, you have to know the voicemail group number to dail it. Sorry i dont know the number to tell you, it could be anything that the installer decided to make it.
Sep 27, 2007 | Mitel Superset 4025 Corded Phone...
Cell Phones Logo
108 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
