Question about Compaq Computers & Internet
Compaq Presario 2700 keeps saying windows didn't start successfully then shuts down and reboots even when you try to go in safe mode
Posted by Chris Vanderbur on
Larry Ng
  • Compaq Master
  • 5,966 Answers
Old compaq? 2700 old old relic. 17 years old today (2001 made)
packed full of lint do dought.!!! and overheating.
windows what? xp to 10, what? please do not post.
F8 tell me, its w7? we hope
it came with windows 2000 or XP that is for sure.
what is it now? click control panel, then system
or tell me oldest date of files in C:/windows folder.
XP was born in 2001.
XP is virus magnet and all are infected with 700 exploites +++
a counting and not supported by MS.com
vasta has no self repair modes and is doomed for that 1 reason.
W7 has legs, is it w7? is it running IE11," if yes its W7
self shuts down fans and screen goes black,>?
no errors to screen
no text errors,
no beeping no blinking caps lock led codes.
steps that work on all old PCs like this.
  1. remove that 17 year old shorted huge batter and leave it out.
  2. now the RTC coin cell is bad, not one ever ran 17 year ever.
  3. next we clean all that lint out of all vents and RAD and fan or it will overheat for sure and all PCs shut off if overheated.,
  4. Next test HDD, if its dead no repairs are possible so we fix that next.
  5. then load linux best on this old PC, or w7 might work but costs $120 to try it. no free try like W10, at all,
clean all vents
all oF big RAD
and fan blades.
http://pcdied.com/overheated.html
Posted on Sep 29, 2018
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: presario v4000 will not boot up
hi,, this compaq is fucking,,,,,,,, even i got the same problem
Posted on Nov 29, 2007
Anonymous
  • 22 Answers
SOURCE: Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
Posted on May 19, 2008
Anonymous
SOURCE: sleep mode troubleshoot
diver sound instaletion
Posted on Sep 17, 2008
mumma_1
Debs
  • 903 Answers
SOURCE: windows will not start up
choose start windows in Safe mode, if it starts then everything will look big, don't worry about that for now. Then go to Start>accessories>system Tools>system restore and choose a date when you know that everything was working normally, when it has finished restoring the computer will restart. If asked choose start windows normally.
I hope this helps
Posted on Nov 25, 2008
Anonymous
  • 197 Answers
SOURCE: Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
Posted on May 28, 2009
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
LCD Monitor (Model Number M17FBA) Signal Out of Range
Hi
Start the computer in SAFE mode. F8 before Windows starts. Once in SAFE mode change the screen resolution to 600 X 480. Do this by right clicking anywhere on the desktop. Once done then reboot into normal mode.
Jun 03, 2010 | Scanport 17" LCD Monitor
I brought my hp about 2 years ago it worked for about a month now im trying to fix it but when it comes on it goes to the screen where it asksstart windows normally how do i reboot
You can choose to start windows normally and it should bring you to regular desktop. If not to reboot you actually have to shut it off by holding down power button until it shuts off. If still issue try to boot in to safe mode by pressing F8key on boot up and keep on pressing it till advanced start up comes up. Once in safe mode try to run virus scan to see is there any viruses. Also in same menu there is safe mode with networking if you choose this one you can do updates since it will allow you to go online even that you are in safe mode. This might resolve the issue.Hope this helps.
Jan 16, 2010 | HP Compaq Presario SR2150NX PC Desktop
May 22, 2009 | Compaq Presario R3000 Notebook
Compaq Presario 700 PC Notebook ''they keep start up they dont wanna gotrue open the windows'' Problem when shut down when i start up again they keep start up showing the window xp and re start back again...
When turning on the computer keep pressing F8
Select boot into safe mode
Then in safe mode click start then run then type in MSCONFIG
Click on Launch System restore.
Restore your computer to the day beforeyour problem started.
Mar 06, 2009 | Compaq Computers & Internet
MY COMPAQ PRESARIO 5000 WILL NOT OPEN WINDOWS XP.
Does your desktop comeup and give any time before it shutdowns, say 1 minute or something like that,
You can log into safe mode and do system restore by pressing F8 once you power on the computer, but you need to keep on pressing till you see the safe mode option.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
My Compaq Presario Will not even show curser after start up
reboot and keep pressing F5 go to safe mode if u can see the screen , u need a video driver ,or try reformatting and re installing windows,
Nov 12, 2008 | Compaq Presario 5000 PC Desktop
Laptop start up problem
go into bios and turn off virus i assume you have xp
Oct 25, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
