Hi I have Harmon Kardon Subwoofer HKTS 210/230. There is no sound. All connections have been checked and wires. Sub connected correctly. Sub has permanent flashing white light. Any ideas
Posted by Rachael on
Tim Bridgman
Hi, I Have the same problem. Did you ever find a solution for this?
Posted on Oct 16, 2021
Henk de Ruiter
  • 80 Answers
R23 and C5 replace them
Posted on Sep 07, 2020
  • Tim Bridgman
    Tim Bridgman Oct 16, 2021
    Please could you elaborate on what you mean by this? thanks
5 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Posted on Dec 16, 2008
Anonymous
SOURCE: harmon/kardon computer speakers not working, light on, no sound
I have my own resopurce already but the thing is you need to spend money for the repair. I contacted a service engineer for the unit and they sy it can be repaired.
Posted on Feb 04, 2009
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
Anonymous
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Posted on Jun 09, 2009
Anonymous
SOURCE: No sound..amp has power to it
After three days of torture, I was going to rip it out, until I decided to make a fresh ground. I drilled a small pilot hole and got a brand new self tapping screw...voila!!! Works like a charm.
Posted on Sep 19, 2009
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Hkts 12
It is either blown or you are overloading it and it is close to blowing. Check your wiring and make sure your amp is matched properly with how you have it wired.
My hkts 15 subwoofer sounds blown. Ive tested the speaker and its not. I sent it in for repair and they could not find anything. Now I thinking its the amp? One day it started working fine and then sounded...
It could be either bad parts or bad solder connections or both but I agree with you if did what you said. Amp will have to be run for a while to know if it or something else.
A scope monitoring the line with the issue will be able to see when it fails.
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
1helpful
How to connect the subwoofer to my Tv Samsung???
Most of the time there is a foldback of the left and right audio inputs of the subwoofer in that they use and sum the L and R audio and then filter the high end off. That means that the audio outs from your source be it the TV audio outs or a AV receiver that they can be Y corded to the sub woofer for that purpose.
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
4helpful
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Harmon Kardon HP spkrs can't get subwoofer output
Just a thought is the output to the sub switched off on your computer?
Harmon Kardon receiver not compatable connection to subwoofer.
Most subwoofers with RCA type connections are powered subs. They are commonly sold in most hi-fi stores.
Unless your subwoofer has a separate mains lead it will be the wrong type I think.
Ekse
 Grubhead
Grubhead
