Radio Communications Logo
Max Bailon Posted on Sep 28, 2018
What do i do if my iworld wireless earbuds stay red after charging and wont turn on even after holding the power button
3helpful
3answers
My iHip Bluetooth ear pods are not bluetoothing.
To pair with bluetooth, it depends on your model (TWS, SoundPods)
  • Turn on Bluetooth on your device
  • Remove one or both earbuds from the charging dock. The earbuds will have a flashing blue and red light indicating they are ready to pair
  • Long press the multi-function button for 3 seconds to power SoundPods on. When the Earbud LED Indicators flash red and blue, they are ready to be paired.
  • from the manual, https://manuals.plus/ihip/tw003-soundpods-wireless-earbuds-manual#ixzz7bR6q1b9Z
    2helpful
    2answers
    I've owned my LBT/JBL Vibe earbuds for a while and both were working yesterday and charging fine now today only one is working and the other one is charged but it will not work?
    looks like holding for 5 seconds enables manual pairing of each earbud
    https://manuals.plus/jbl/vibe-300tws-true-wireless-earbuds-manual#manual_setup
    2answers
    Why won't my pasonomi wireless earbuds not turn off
    Press and hold the MFB buttons for about 5 seconds to turn them off. When both earbuds are paired with your cellphone, press and hold the MFB button on either left or right earbud, the other earbuds should turn off at then at the same time.
    1helpful
    2answers
    Charging i7S TWS attached to iMac USB port for 36 hours.... No Blue light yet!
    battery is #1 failure on all portable devices! even 1 year old abused
    replace ok"?
    3answers
    Can't get my wireless earbuds to pair together
    Hello Patsy, indicate brand, model, type of headset and equipment that you are commenting on, in order to find the best possible solution
    I wait your answer
    Greetings Franco Dosil
    Hola Patsy, indica marca, modelo, tipo de auricular y de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
    Espero tu respuesta
    Saludos Franco Dosil
    3answers
    My Bluetooth is stop pairing with my ipad
    To get help pairing a Bluetooth accessory-like a wireless keyboard-to your iOS device, try these steps:
    1) On your iOS device, go to Settings > Bluetooth and make sure that Bluetooth is on. If you can't turn on Bluetooth or you see a spinning gear, restart your iPhone, iPad, or iPod touch. Then try to pair and connect it again.
    2) Make sure that your Bluetooth accessory and iOS device are close to each other.
    3) Turn your Bluetooth accessory off and back on again.
    4) Make sure that your Bluetooth accessory is on and fully charged or connected to power. If your accessory uses batteries, see if they need to be replaced.
    If you still can't pair or connect your Bluetooth accessory.
    1) If you previously connected your Bluetooth accessory to your iOS device, unpair the accessory, put it back in discovery mode, then try to pair and connect it again.
    2) If you can pair your accessory with some devices but not your iOS device, unpair the accessory from your other devices. Then try to pair with your iOS device again.
    3) Check with the accessory manufacturer to make sure that your accessory supports your iOS device.
    4) If you still have any of these issues, contact Apple Support:
    You can't turn on Bluetooth or the setting is grayed out.
    You can't connect any Bluetooth accessories with your device.
    The accessory manufacturer confirmed that your accessory is working correctly.
    Cant figure out how to turn on my Bluetooth earbud
    On many of these Bluetooth devices you must hold the power button or another button on the unit for like 10-20 seconds to get it into "doiscovery" mode. Then use your phone to try and FIND in in the settings-> bluetooth...
    1helpful
    Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
    Indicator Lights:
    1.Headset Status Headset Indicator Light
    2.Powering on Steady blue, then intermittent flashes
    (changes to standby mode)
    3.Powering off Red appears and goes off
    4.Standby Blue intermittent flashes
    5.Charging battery Red solid light. Light indicator turns off when
    battery is fully charged and headset is off.
    6.Low battery Triple red flashes
    7.Pairing mode Blue/red alternating flashes
    8.Missed call Purple flashes. Press the call control button
    to cancel flashing light.
    9.Incoming call Triple blue flashes when ringing.
    Power on and off:
    1.Turn on the headset Press and hold the call control button until the
    indicator glows blue. You will hear ascending
    tones.
    2.Turn off the headset Press and hold the call control button until the
    indicator glows red. You will hear descending
    tones. When power is off, indicator stays off.
    If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
    Good luck from Headsets Direct!
    Top Radio Communications Experts
    eradiostore
    eradiostore
     Grubhead
    Grubhead
    Are you a Radio Communication Expert? Answer questions, earn points and help others
