Question about Cannon Office Equipment & Supplies
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
SOURCE: My xerox machine cannon IR
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Posted on Jan 20, 2011
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
