Question about HP DeskJet 5150 InkJet Printer
I can print from Word on my HP 5150, but it prints multiples
I can print from Word on my HP 5150, but it prints a wierd test page and then and then the original again 3 more times. When printing the document (1st time), on the printer details screen, it shows "4/1" under the Pages heading/column.
Posted by krueger15317 on
Anonymous
    Problem Solver:
  • 6 Answers
Sounds like a problem with the printer software, try uninstalling & then re-install the printer driver
Posted on Aug 06, 2009
I cannot find how to access the ink level on my HP 5150. There is no "service" tab on my "printer preference" window.
let me tell u this means ur printer full feature driver is not installed in ur computer to install the driver u can try this link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=304431&lc=en&cc=us&dlc=en&lang=en&cc=us
and the other way u can check the accurate ink level in by printing a self test page
  1. Ensure the printer is turned on.
  2. Press and hold the Power button.
  3. While holding the Power button, press and release the Resume button four (4) times.
  4. Release the Power button. A self-test page will print.
Feb 23, 2010 | HP DeskJet 5150 InkJet Printer
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
My hp deskjet 5150 will not stop printing
If you are using Windows XP
1. Click start then run then type in cmd then click ok.
2. Type in NET STOP SPOOLER
After that in the lower right corner of your screen you should see a printer icon. Delete the queueu
If that still does not work Unplug the power from the printer then wait for 5 mins then restart your computer and turn it back on.
Nov 11, 2008 | HP DeskJet 5150 InkJet Printer
Slow and blank printing
sounds like clogged print heads. do a clean print heads, then a test page, and see how that goes. Like a sink that gets clogged, when it's not used, print heads need exercise, otherwise, they can get some gunk on them, and no more printing.
Feb 06, 2008 | HP DeskJet 5150 InkJet Printer
HP 5150 will not print from programs MS Works and MS Word.
ayant egere le CD d'installation de mon imprimante hp desjet 5150, je ne parviens pas a installer mon imprimante. ou puis-je touve le driver, le lien sur le site hp.
merci par avance
Nov 02, 2007 | HP DeskJet 5150 InkJet Printer
HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Sep 06, 2007 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
105 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
