SOURCE: ford escap 2006 4cylender the temp gag go to hot
could be a faulty temp sender unit as it activates the fan aswell
cheap to fix
cheers Rob
SOURCE: What is the spark plug
These were still early times for the then new...HEI ignition...The factory was using a 60 mm gap...most mechanics used a 45 mm gap, as the 60 mm was proving to wide for peak performance...I highly recommend the 45 mm gap on your spark plug gapping tool...be sure the electrode is still perfectly straight with the tip when measuring...:)
SOURCE: sparkplug gap for 1965 mustang coup 289 winsor and points gag too please
Plugs .030" Points .017"
Testimonial: "thanks"
SOURCE: my fuel gag is not showing
A mechanic would check for voltage and ground at the connector for the sending unit in the gas tank. Could be the sending unit or the gauge or a wiring problem.
