Question about Kenmore Vacuums
Is it necessary to have a bag in a Kenmore 116 for it to turn on
Posted by Bill Burdett on
Thatvacguy.com
  • Kenmore Master
  • 1,604 Answers
116 is only part of the model number. On most model the answer is no but not knowing your model I can't say for sure
Posted on Oct 23, 2018
5 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: can't figure out how to replace the bag
Open the hood, bag #20-50557 , the cardboard part goes in the bag holder, will only fit in one direction, then close the hood.
Posted on Jun 22, 2008
advacak
Denny Adams
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
Doug Connell
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
sandham
  • 52 Answers
SOURCE: dont turn on, is there a fuse and where?model 116
yes there could be a fuse and it is most likely in the motor chamber behind the motor
Posted on Mar 01, 2010
bmosley354
SOURCE: My Kenmore model 116 33300300C
If it is a burning rubber smell it may be the belt slipping. Make sure your brushes are clean and spin freely and then put the belt back on and see if that helps.
Posted on Apr 05, 2011
We have a Kenmore Progressive Model 116 Upright bagged vacuum with Hepa filter. It's at least a couple years old. For quite some time now when ever we use the vacuum the vacuum motor will shut off nafter...
I suspect that you have a restriction. The motor sounds like the thermal break is stopping the motor before damage, due to heat.
You must witness that the entire suction and discharge side are clear. This is not always very easy, but necessary. I bet that you find something blocking somewhere...
Nov 13, 2010 | Kenmore 34612 Bagged Upright Vacuum
Dont turn on, is there a fuse and where?model 116
Mar 01, 2010 | Vacuums
How I replace the belt for Kenmore 116 3063500C ser M53101631
Turn it over and on the bottom are (2) screws. Remove those and the top cover will come off and you can access the belt.
Jan 08, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Will not turn on
I would start with replacing the cord end. Especially if you have had it for a few years.
Jul 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore 116 bagged canister vacuum
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Can't figure out how to replace the bag
May 03, 2008 | Kenmore 22812 Bagged Canister Vacuum
Vacuums Logo
81 people viewed this question
Top Kenmore Vacuums Experts
Marvin
Marvin
jdthefixer
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
