HP LaserJet Printers - 'Install Black Cartridge' Displays
https://support.hp.com/us-en/document/c02476541
If your printer display panel shows the error black cartridge in use. Tap on the OK button and clear the message. Consider changing the toner cartridge. You can purchase the toner cartridge from HP Store.
1, Make sure that you use HP toner cartridges for printing.
2, Before replacing the toner, check for packing materials and paper.
3, Switch off the printer and disconnect the power cord from the printer.
4, Access the toner cartridge door and check for any packaging material or any debris in the printer.
5, Take the toner cartridge out from the printer.
6, Check and remove the orange tab on the toner cartridge.
7, Gently rock the toner cartridge and make sure that the toner is distributed evenly.
8, Place the toner cartridge into the printer and then close the toner cartridge door.
9, Reconnect the power cord and then Power on the printer.
10, Check the printer for any jammed papers.
11, Take a clean link free cloth to remove any dust or debris from the electric contact.
Resetting the printer will resolve most of the printer issue.
For more printer queries just give a call @ 1-866-293-9220
If the machine is still printing normally - don't worry about it. If the cartridge is a refill, or you have re-installed a part used cartridge the printer will have registered a serial code or the chip has not been replaced with a fully compatible one. If the cartridge is an original and still within it's expected life, you may have a developing problem with the printer.
SOURCE: Cartridge problem
the problem is that even if you dont use the color supplies they do have a life cycle clock, you could try reseating the cartridge but i doubt that will work. what needs to happen is that the chips need to be reset or replaced on the color cartridges, its cyan now soon it will be yellow and then magenta. you can 1) replace the cartridges with new ones orr 2) have a cartridge refill place replace the chips on them. they dont need to be refilled unless the toner from age and humidity became soild. what most people dont understand is that if all you print is black then dont buy a color laser printer. toner over time can become a soild chunk and ruin your cartridge. most laser cartridges have a 2 year shelf life thats seald in a air and water tight bag in open air the toner starts pulling in the humid air and starts to become soild, this can take anywhere from a few weeks to a few years.
SOURCE: My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
