Question about Honda Electrical Supplies
Bosch 11335K Jack hammer, motor runs, hammer doesn't.
Maybe 30 minutes of run time on this hammer, but we had another one that did the same thing. Runs off a 3000 watt Honda generator. What are we doing wrong?
Posted by Shawn Redfield on
  • maurice guenser
    maurice guenser Jan 03, 2019
    Have you checked the oil level mate, i dont your model but i remember years ago using one and it stopped working as the oil had run out, topped it up and away it went, they normally have an eye glass under the handle
maurice guenser
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
I thought id answered this, if there is an eye glass check the oil level mate, its normally below one of the handles, sometimes you can screw the eye glass off and top up
Posted on Jan 03, 2019
5 Related Answers
Anonymous
  • 2336 Answers
SOURCE: runs for 30 minutes then dies
try running with fuel cap open. If it keeps running, breather in fuel cap blocked, strip fuel cap and clean.
Posted on Nov 10, 2008
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: motor runs but have no power coming out of outlets of mygenerator
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
Posted on Nov 29, 2008
Anonymous
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
Norman Al-Anbar
  • 630 Answers
SOURCE: i have a honda em3500 watt generator that runs
it could be the connectors need to be changed, when you open the front of the gen you will see a shaft with wires attached to it in both sides a small charcoal like peaces attached with a small wires each these connectors see if the are touching the shaft or not and how long they are if they not or too short that mean you need to replace them and you can get them from any please by looking at the manual and get the number for them and do search on the net or local store...However did you first reset all your brakes? let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
A ball bearing problem or broken piston drive rod ( its modificated by 1607000C3P) also best is to service with maintenance kit 1617000702
Sep 27, 2018 | Bosch Drills
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 | Drills
How much grease goes in a bosch 11335k?
I believe this tool takes 225 ml of grease, but I would strongly recommend installing a service kit #1-617-000-702
The service Kit comes with grease and all the normal wear parts (highlighted below in black circles) Service Pack 1617000702 for Bosch Power Tool eReplacement Parts
Jun 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Jul 03, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
Bosch 11247 rotary hammer will not hammer
SAME ISSUE *****SOLVED*****
You were on the right track but needed to go farther with top description without disassembly!!
I have a barely used Hammer drill also that will rotate and run motor but does not hammer in any position.
Grease is the issue.....
Heat and sitting causes the grease to weep out & even a small amount of dust binds up the hammer drill.
******SOLUTION*****
GREASE, GREASE & MORE GREASE....
REMOVE BIT....SQUIRT IN ALOT OF THE BOSCH GREASE HOLD LOCKING CHUCK OPEN. INSERT A SPLINED BIT INTO THE HOLE AND PLUNGE GREASE IN SLOWLY SEVERAL TIMES. REMOVE BIT & REFILL GREASE & REPEAT.....VOILA.....HAMMER WORKING AGAIN....
BE SURE TO USE LOTS OF GREASE & DUST COVERS ON Bosch HD WHEN WORKING. WE ALL ERROR AND FAIL TO MAINTAIN FROM TIME TO TIME!
Feb 19, 2012 | Drills
It starts then it stalls, sometimes it starts right up some times it doesn
It could be the Crankshaft Position Sensor - My 1993 Bonneville with a 3.8 had the same issue, I replaced that and it works great now.
It had codes:
17, and 18 I think, or maybe 19 stored. Which was Cam Position sensor, and Crank position sensor problem.
The crankshaft position sensor is easy to replace, if you have access to a pulley puller, some tools and a jack or lift. Some motors need a special tool for an adjustable thing, but most dont have that anymore as I think they recalled it and replaced it on all.
I think they run about 30-60 for a new one, and takes about an hour to replace.
If it is intermittent start problem that may be it. Mine would start fine for a while, then sometimes after Id turn it off, it would just crank and crank, It would start after waiting about 5-30 mintues, while trying to crank it every couple minutes. When driving down the road, it sometimes would stall when turning or stopping.
Hope this helps - Jarett *mechanic with 14 years of experience
Jun 22, 2009 | 1992 Pontiac Grand Am
Breaker Hammers Features
power, raw strength, comfort and vibration
Aug 27, 2008 | Bosch 11335K Factory-Reconditioned 35 lb....
Electrical Supplies Logo
277 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Marvin
Marvin
Mike
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
