Question about Haier Refrigerators
Haier HRF-66315B2/U. The ice cube tray isn't filling with water. the manual directs me to check the water feed. the water feed appears unblocked.
Water is coming through the water dispenser on the front of the door, but slowly. Any ideas on what is causing the problem and how to fix please
Posted by Sami on
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Posted on Jun 13, 2007
francis rivero
  • 958 Answers
SOURCE: water comes out the cubed ice portal and does not fill ice tray
scottt57 could have switched the wires on the solenoids. try switching them and observe where the water would come out..
Posted on Feb 12, 2008
George Fleming
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Ice cube tray isn`t filling with water but I have
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut.
If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged.
If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve.
If no water comes out of the valve, change it.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on Jun 05, 2009
Anonymous
  • 35 Answers
SOURCE: Water will not fill my ice tray. I have good water
THE WATER VALVE IS BAD
Posted on Jun 18, 2009
Raritan icer-ette only filling 5 of 8 slots in ice mold
They marine ice makers are fussy. The ice maker needs to be level or water will drip down into the ice bin. The amount of water entering the tray is controlled by time. The other factor is pressure. The marine water system has a relatively low water pressure as compared from marina water feed.
I would confirm the number of cubes produced from the unit when connected directly to the city water pressure. If at the highest pressure it is below expectations I would follow the video. How Do Adjust an Icemaker Home Appliances
There is a screen filter before the solenoid line that can fill with debris. So you may need to check it if you can not make a satisfactory adjustment.
If you are like me and always work form the internal water tank avoiding a burst water line and "sink the ship" then adjust it for the lower pressure.
Happy Sailing
Dec 09, 2015 | Raritan Icer-ette Ice Cube Maker
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
Ice tray not filling
The unit will not allow water to enter the frig til the temp is cold enough to make ice.
Nov 06, 2012 | Bosch Refrigerators
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Wont make ice
For the moment I would like you to fill the ice maker with tap water unless the cubes are stuck there. Most times the water control valve on the rear are the problem. One side feeds the dispenser and the other feeds the ice maker. Model number Y13068002 Let me know if it will drop ice after filling tray with water. If not the focus will be on the ice maker. During that time I will get you a service manual if correct model number and a place to find parts to get yu going again, Thanks, Se Breeze
Jan 15, 2010 | Refrigerators
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
