Question about Kirby Vacuums
I have a Kirby g5 and when you put it in drive it goes put when you pull back it doesn't let go it just stays in drive with the wheels turning and won't stop into you put it in neutral what can be the problem
Posted by Chris Urbanski on
Thatvacguy.com
  • Kirby Master
  • 1,604 Answers
The transmission may need adjusted.
Posted on Oct 23, 2018
5 Related Answers
Anonymous
SOURCE: Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Posted on Jul 16, 2007
Uplate
  • 112 Answers
SOURCE: Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Posted on Jan 04, 2008
RockyNR1
Rocky
  • 324 Answers
SOURCE: Drive/Neutral lever fell off Kirby G5
Manual on how to do it - take a look HERE
Posted on Dec 02, 2008
b0sslady2001
Marci Marple
  • 357 Answers
Please check out my brand new FREE online guide for this repair......
http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL_W0QQugidZ10000000011180003
HOPE IT HELPS!!!
Marci
Posted on Mar 17, 2009
VacuumRepair
Chris Jones
  • 438 Answers
SOURCE: how do I replace the drive belt on a Kirby G5
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J
Posted on Mar 21, 2010
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
KIRBY g5 wHEEL CHANGE
It is 0.027 inch thick and 0.28 inch inside diameter.
Or just go HERE and buy it. However we ship only PRIORITY and we have 2.00 handling charge so shipping for 0.75 clip will be $7+ but if you will throw in some bags belts - it will make sense.
Tu put it on - I would not buy any special tools. Simply push it onto the axle with tip of pliers. if you end up bending the clip and it does not stay on - use pliers to shape it back to original shape and try again.
Wherever you buy it - buy 2 or 3 just in case if it gets lost.
Good Luck,
Rocky
Apr 06, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Dec 24, 2007 | Vacuums
Kirby G5
The transmission needs adjusting. Just a little fine tuning. See if you can find a repairman near you, or you can contact us at 1-866-509-1952. Thanks
Jun 16, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
90 people viewed this question
Top Kirby Vacuums Experts
Marvin
Marvin
Lollo Pop
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
