Question about Skull Candy Audio Players & Recorders
Need help pairing lg6 with skull candy wireless speaker
Posted by Janet Markham on
5 Related Answers
Michial Gueffroy
  • 1140 Answers
SOURCE: HOW TO GLUE POLY CARBONATE
You might try using two part epoxy. It comes in two tubes and you follow directions to mix one drop of each together to make the epoxy to use to glue the parts together. For best results the parts glued together shouldn't be disturbed for 24 hours. I have used the Locktite brand with good sucess.
Posted on Apr 29, 2009
kirtec auto
  • 1348 Answers
SOURCE: how to replace the male plug of my icon skull candy headphone.
there are 3 wires.A ground,usually a braid on the outside under the plastic covering and 2 other wires, one for left and one for right.the size of plug is a 1/8 phone jack.the wires are very thin and you have to make sure to trim just enough plastic to solder it on.too much peeled plastic will create a short,and you have to be good at soldering to do it.
Posted on May 13, 2009
Anonymous
SOURCE: skull candy double agent headphones wont turn on
I had the same problem and realized that it was because the SD card must be formatted as FAT16 not FAT32 or NTFS.
Posted on Oct 12, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: How do i make my bass louder for my skull candy
Try this site:http://www.skullcandy.com/forum/faq.php You will have to ask directly as the solution will vary with the model number and what equipment you are using them with.
Posted on Oct 24, 2009
Grubhead
Grubhead
  • 5750 Answers
SOURCE: My skull candy skullcrushers's audio jack fell out.
Simply cutt what is left of the old plug off and buy a new plug. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Posted on Mar 22, 2010
My skullcandy wireless headphones are still connected to my old phone and I don't know how to unpair them please help!
I take it that you mean to say Bluetooth not wireless as to unpair the phone is needed to delete the pairing from that end
the phone is needed to wipe the pairing code from it untill the code is wiped from the phone it is capable of connecting to your skull candy headphones but you would need to be within 10-20meters for that to happen
2answers
Bluetooth code for skull candy
The code will be on the booklet the came with the box
2answers
Need a manual for a skull candy pipe
Improve the FixYa experience for everyone by voting.
Unfortunately, the company has no free download site. However. you can have a manual provided by contacting the company at:
Phone: 1-435-940-1545
Fax: 1-435-214-2566
Email: [email protected]
I have no personal interest or association with any product that I may suggest.
The jack broke off of my skull candy skull crushers, and i was wondering how i can fix this problem?
There isn't really a way to fix it if that happened. Lucky you, though, you have Skull Candies! Skull Candy has a lifetime replacement program that will replace your headphones for free if you say you broke them from an accident or just from eventual wear and tear. If they were broken from obvious aggressive use, Skull Candy will still give you 50% off a replacement pair.
Requesting replacements is easy. You just answer a few questions about them, such as around when did you buy them and a short explanation of what happened, then they will send you a special box. You mail them the box back with your headphones in them, and they will send you the replacement pair!
Go here to fill out the quick replacement form!
Skull Candy Warranty
I have a pair of Skull Candy and my grand daughter cut the cable,can they be repaired
They probably could be repaired, but it would require stripping of the wire and connecting the correct wires back together.
In other words, you would be better off buying a new pair.
My dad just got me these new skull candy earphones ive had them for about a month and a half at night i wrap them up neatly when in my pocket i wrap them around my ipod and now i dont know why but the left...
This is very common with Skull Candy headphones as the jacks are very poorly made. I went through 4 pairs of them within 4 months. Unless you want to buy a new pair every month, buy a reliable brand (Sony, Panasonic, etc.). You can however get them replaced with the same product by visiting:
http://ca.skullcandy.com/warranty-information.html
Hope this helps
3helpful
The left side wont play music but the right side will play it completely
hi there, I had skull candy earbuds in the past. The problem is that the left side has a short in the speaker. It means that you need to get a new pair of earbuds as they are not fixable.
2helpful
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
woodzowl307
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
