Question about Golf
I have a 2007 Yamaha Golf Cart Model YDRE. When I turn the on / off switch it does not do anything.
Posted by Charles Lowe on
2 Related Answers
Wes Keener
  • 24 Answers
SOURCE: Golf Cart Wiring
James can you trace the wires back to the source? Sometimes there are 12v accessories such as a fan or radio on those that would require you to hook up the wires on the positive and negative from two connected batteries to get a 12v output. So in your video, all you would have to do is move the small black wire to the negative of one the batteries connected to the one with the yellow bungie. The red wire should be okay where it is. Trace the wires back if you can, but hopefully this helps. Good luck, sir.
Posted on May 24, 2013
Vernon Taylor
  • 6838 Answers
SOURCE: Should the solenoid have increasing voltage across the main terminals, 9.0vdc to 30vdc. Master switch in tow, key switch off.
My answer is I don't know regarding golf carts but generally a designer would arrange for a solenoid to be actuated by as constant a voltage as possible, especially if it is to be engaged for long periods. That is the only method to ensure consistent operation without danger of overheating. This is assuming the available voltage energises the soleniod.
I would expect the voltage across the main terminals would also be expected to be fairly constant so a predictable consistent performance can be provided over a long life.
You really need to consult a repair manual/wiring diagram. As a complete uninitiated golf cart layman I would expect the main solenoid switch to be switching the battery voltage which would then supply the speed and direction control board. I could be worng though!
Posted on May 02, 2016
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 | V Golf Golf
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
I have a 2007 Yamaha golf cart The serial number is JW2-104176 what model is it?
Hi, Christine for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 26, 2016 | Yamaha Motorcycles
I have a 2008 Yamaha YDRE electric golf cart, I replaced the solenoid. I have checked the key switch, the f/r switch and the toggle switch. I only have a positive reading on one side of the solenoid.
Only the battery side of the solenoid will be live until it receives an energising supply from the control circuitry and closes. In the energised and closed condition both sides of the solenoid will be live.
If an energising supply is present at the solenoid coil the solenoid could be faulty. If the energising supply is absent the control circuitry is at fault. Tracing the fault could be made easier by referring to a wiring diagram.
Oct 14, 2016 | Golf
May 02, 2016 | Cars & Trucks
Yamaha golf cart
Look under the seat for a pressure switch.
Mar 26, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
How to wire a stereo into a G1 yamaha golf cart
all you need is a live wire which may be a switched live or a permanent live directly from the battery( switched live means the wire becomes live when you turn the ignition key) The chosen wire must be connected to theb radio via a 3 amp line fuse
Jun 26, 2012 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Golf Logo
409 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
