Question about True Freezers
Can the temperature be adjusted on the true GDM-49F
Posted by John on
Dennis Boxerman
  • True Master
  • 1,303 Answers
Https://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-GDM_iom.pdf
Here is the site for the ops manual. should walk you thru how to do temp adjustments.
Posted on Nov 19, 2018
5 Related Answers
roadbird383
Michael Calligan
  • 40 Answers
SOURCE: TRUE freezer model number GDM-49F.
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Posted on Dec 14, 2007
jason zeringue
  • 141 Answers
SOURCE: I have a true freezer
well most t stats have a differential of 5 to 7 but almost never more than ten deg so that the compressor wont short cycle .something you can check .some t stats you can adjust the differential on check if yours has that adjustment screw on the side or back of T stat if you need more help or parts e mail me at [email protected]
Posted on Oct 01, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Do you have a wire
You have to contact True and they will send it. They do not have this on their web site. Just user manuals. 1-636-240-2400
Posted on Nov 03, 2010
aaronbeth
Aaron Beth
  • 110 Answers
SOURCE: product in my true gdm-49f
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Posted on Jan 20, 2011
mike cooper
  • 884 Answers
SOURCE: I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
Posted on May 04, 2012
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
I have a true freezer m/# gdm-49f s/# 5140302 ... this unit is set at -17* it runs fine when it gets to the set point turn off of course by it doesn't come back on until it reaches 0* .... I like to...
Sep 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True upright freezer. coil fan not running.
Let it run. Coil temperature has to be low enough for the fan delay switch to close.
Jul 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Temperature at 10 degrees
check condenser fans, if defective or running slow change it
if condenser fan is running, suspect a compressor with internal mechanichal problems, it will run but i can't guarantee how long, maybe a couple of weeks or days. if it's an copelamic compressor, it's going bad.
Apr 21, 2008 | True 49 cu. ft. / 1388 liter Commercial...
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
Freezers Logo
365 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a True Freezer Expert? Answer questions, earn points and help others
