SOURCE: Panasonic Dp-190 Displays
Hi, your problem is comming from the exhaust fan ( fuser unit side ) It is probably defective but you can check to see if the connectors are plugged in properly. You can also check the LVPS connectors. If none of these works, your problem is going to be located in the LVPS or the engine PCB.
SOURCE: panasonic kx-mc6020 showing error call service3
How to clear paper jam error after paper has been removed
SOURCE: my panasonic dp-mb300 printer show a problem call service 6 how do solve
My printer Panasonice probleme Copy
SOURCE: Call service3 error in panasonic kx mb772
Turn your machine on.Open menu and press #9000# and then press 550 followed by START. Then turn off your machine!
