Question about Grohe Plumbing
Grohe Ladylux 3 Cafe - the sprayer won't stay on.
Posted by Robert Bradanini on
5 Related Answers
Anonymous
  • 88 Answers
SOURCE: grohe ladylux cafe-no manual
hope this helps
Posted on Sep 30, 2009
Daichi Hayden
  • 52 Answers
SOURCE: Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Posted on Feb 15, 2010
Anonymous
  • 3 Answers
SOURCE: how can I clean the inside of my grohe ladylux
If you h ave the spray head that comes out, just remove the pressue regulator. The little white plastic thing inside the end of the spray head. Pry it out with a tiny screwdriver...may come out in pieces, but it solved my low pressure problem
Posted on Mar 08, 2010
thomas gowen
  • 92 Answers
SOURCE: grohe ladylux cafe kitchen faucet:
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Posted on Sep 07, 2011
cheetohman
  • 21 Answers
SOURCE: How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Posted on Jun 07, 2014
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
Jun 03, 2014 | Grohe Plumbing
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
I'm trying to replace the flexible hose on my Ladylux Plus but the hose doesn't seem to pull through.
If you remove it from the sprayer and then pull it out the bottom it should come out quite easy and you will also need to remove the weight and add it to the new hose after the new one is installed.
Aug 22, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I need a parts list and assebly instructions for a ladylux cafe
Hi. There are 6 different types of LadyLux Cafe. If you go to http://www.grohecatalog.com/line/LadyLux-Cafe you can choose your product and they have a parts list and an exploded diagram of each product. This should help and at least get you going.
Regards, Myles
Dec 31, 2010 | Grohe Plumbing
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Plumbing Logo
297 people viewed this question
Top Grohe Plumbing Experts
john h
Thomas F. Schneider
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
