see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might
be jammed. Try removing the brushroll assembly and cleaning all hair,
string, lint, etc. from the brushroll bearing. If that doesn't solve the
problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly
itself might be jammed. Try removing the brushroll assembly and cleaning
all hair, string, lint, etc. from the brushroll bearings. If that
doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might
be jammed. Try removing the brushroll and cleaning all hair, string,
lint, etc. from the brushroll bearings. If that doesn't solve the
If the vacuum cleaner brush is not spinning the cogged belt might be
broken, stretched out too much, or might have fallen off. Check the belt
and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be
If the vacuum cleaner brush is not spinning the belt might be broken,
stretched out too much, or might have fallen off. Check the belt and
replace as needed.
