Question about DISH Network Televison & Video
Dish Network VIP211 receiver keeps shutting off and updating programming guide. What is the fix or is it indicator the receiver is gone bad?
Posted by Cristina Johnson on
Will
    Habit-Forming:
  • 91 Answers
If it's a silver colored VIP211, it's one of the older models and should be replaced soon. (They go defective very often.) Contact Dish and call them to have it replaced, they can either ship you out a replacement receiver or have a tech come out to replace it. If you activate Dish protect silver on your account it can save you from the $95 tech visit fee. Hope this helps! :)
Posted on Mar 27, 2020
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
What time does the program guide suppose to download
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you. All of ur receivers are set to update nightly between 1am to 3am. The nightly updates allow the receivers to update software and the programming guide. if you need to force a download on the guide simply unplug the receiver from the wall outlet for 10 seconds and plug it back in, allow it to power back on by itself, acquire signal, and download the guide. If you have any questions or need assistance with your DISH service, feel free to reach me at: [email protected]
Kimberly Escobar
Social Media Representative
DISH L.L.C
Sep 13, 2013 | DISH Network ViP722 DTV Receiver /...
A tv code for the cntrol of vip211 converter remote control
wilroshana
I have provided a link with instructions on how to program your remote to your TV. The link includes (bottom of page) another link with your receiver model and all the codes for different TV manufacturers. I hope this helps.
Ray Calo
DISH Network
Mar 03, 2011 | DISH Network ViP 211 DTV Receiver
The channel guide only shows no information available most of the time
sidbashford
You are getting that message because the receiver is not updating the Electronic Program Guide (EPG). Try unplugging the receiver from your electrical outlet for about 10 seconds (make sure all lights on receiver go out) and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. Allow it also to download the program guide. After you get your channel back, pull up your guide, go into the future to see if it updated.
If it did not update, you'll need to run a check switch test. Press Menu on your DISH remote; should have Main Menu on TV screen. Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get to Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Televison & Video
ViP211-HD DVR button won't work.....can't record any channels.....also the 'record' button doesn't respond either......
Hello, my name is Matthew Gonzales with DISH Network. I'm sorry about any inconvenience, but the ViP211 is not a DVR receiver. If you have an external hard drive, you can activate the feature on the 211 to allow you to record movies to the external hard drive. It is a one time $40 to activate the external hard drive feature. Also, we can always look at getting a DVR receiver installed to replace the 211. If you have any other questions, feel free to email me at [email protected].
Dec 02, 2010 | DISH Network ViP 211 DTV Receiver
Will this receiver work with a dish 500 antenna to receive standard channels only
Hello, this is Matthew Gonzales with DISH Network customer service. To answer your question, yes the ViP211 will work with a dish 500. It will receive the standard channels as you asked, but if you wish to get HD, the dish on your home will need to be upgraded. Hope this helps!
Aug 28, 2010 | DISH Network ViP 211 DTV Receiver
Would like to have or view vip211 receiver manual to utilize all possible connections.
Hello, Matthew Gonzales with DISH Network here. If you no longer have the manual for the ViP211, it can be found at http://www.tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/211.shtml.
All other receiver manuals can also be found here. Hope this helps.
Jun 15, 2010 | DISH Network ViP 211 DTV Receiver
I cant connect my dish vip 211 to my tv with an hdmi cable anymore after using standard definition for sometime now
Hi swizz33 onthe VIP211 receiver there are many different connections you can use besidesthe HDMI cable to connect your VIP211. You can use the RCA cable as well as aCOAX cable and there are the Component cables you may use and all of those typesof cables will give you picture and sound.
Jun 01, 2010 | DISH Network ViP 211 DTV Receiver
Dish program guide
this is a problem dish network is aware of and trying to fix, 311 receiver??
Aug 02, 2008 | DISH Network IR Remote Control
Televison & Video Logo
145 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
