SOURCE: plasma model pdp-433pu loud pop
Sounds like it could be a power supply.
let me know if you want to sell it.
naturboy-at-ufl-dot-edu
SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
SOURCE: how do you enable the pioneer plasma hdmi settings
Hi BarryHird
on your remote press/ home menue/option/HDMI input/setting,enable that should do it..
SOURCE: The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. Some times, the ads
attached with each posts, both at the right and bottom, might help you to find
the availability of spare parts. There
are more than 730 posts to different brand TVs now.
Blinking codes to Pioneer Plasma TVs have been described in detail there.
