Televison & Video Logo
G
Glenn Bailey Posted on Sep 23, 2018
My 5102 digi code receiver is not working. Not sure what the problem is
Code c 5102
The 5102 and 510x codes refer to main or fuser motor malfunction.For more help please the copier model.
1helpful
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
I have a Konica Minolta Bizhub c252 what is code c-5102
C-5102/5103 - Main motor failure.
Check the motor connector,the drive coupling or the mechanical control board and DC power supply unit.90% mechanical rpoblem.
Malfuntion code c-5102 for oce imagistics cm2520
C 5102 - Main motor malfunction.Check the I/U unit gears,Fuser unit gears it is a mechanical locked problem.
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
2helpful
LOst manual to setup Sagem ITD59g digi box.
press menu installation, then tap in 1,2,3,4 on remote for access code then choose user setting to take you to tuning menu
2answers
Att uverse remote won't turn on yamaha reciever
Yamaha Receiver/Amplifier 5003, 5014, 5015, 5021, 5102, 5103, 5104, 5105, 5106, 5118, 5135you can use those codes
11helpful
3answers
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
Top Digi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
