Cameras Logo
Question about Sony Cameras
I tried to copy my pictures. but win10 could not read my card and the camera says the card is unusable and needs to be reformatted. Is there a way to recover the photos ?
Camera is a Sony a6000 which was working fine. The SDHC card is a 32gb Lexar Professional 1000x I viewed the pictures after each day and they were fine. Thanks [email protected]
Posted by Kenneth Landry on
Malcolm Fowler
    New Friend:
  • 31 Answers
There are software available for image recovery from SD and SDHC cards. One good one was produced for free by San Disk. It was called Rescue Pro. Others are available too, here is an example, there are others.
https://www.cardrecovery.com/?rid=google&kid=cr0103&gclid=EAIaIQobChMIv-GD6aGn4gIVCJ3tCh3hugT2EAAYASAAEgK3I_D_BwE
Posted on May 19, 2019
5 Related Answers
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: Sony Vaio desktop with service pack3 not reading a 4GB SDHC card
does the card work in any other device?
Posted on Nov 14, 2008
Anonymous
SOURCE: problem with Nikon d90
unlock your card. you'll get that message when the SD card is locked.  Lock the card only to prevent deleting photos from it. good luck!
Alberto
Posted on Mar 07, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
Anonymous
  • 11967 Answers
SOURCE: Hi: I have a SDHC 16GB card using by the Lumix
At any time did you insert the card into your computer to "have a look" and then remove the card without using the "safely remove hardware" function? You may now need to download the pics from your card to the computer, then format the card in the camera to get it to work properly again.
Posted on Apr 14, 2010
Testimonial: "Typrice is patient and to the point. I appreciate him sharing and helping me in this issue."
Anonymous
  • 64 Answers
SOURCE: Trouble viewing images
it should be photo carving issue. you can find more info from
http://www.asoftech.com/advancedcarving.html
Posted on Oct 26, 2012
I can no longer view my picture on my SD card. I renamed the folders using my laptop to text names. Do I need to renumber the folders for the camera to be able to display the photos? (Ex. 1001-001?).
You have probably corrupted the card - cameras have limited internal software to read cards, and if the data is not in the expected format, the camera cannot read it. Also, by not setting write protect on the card before inserting it in the computer, the computer will have added files which will further affect the camera.
Your best bet is to copy the files to your computer, then reformat the card in the camera and treat it as a fresh one, only re-naming files once you have copied them to the computer. You will not be able to copy the files back to the card so they can be read by the camera no matter what you do.
Jan 14, 2019 • Cameras
1helpful
2answers
I have a canon powershot sd 1200 is. I tried to transfer the photos from the camera into a laptop using the memory card; t didn't work. Put the card back into the camera. Now camera says...
This sounds like your card has some type of error that is causing the images not to be seen. My suggestion is that you go to your local chain pharmacy (such as Walgreens, CVS, Duane Reade) and put your memory card into their photo kiosk machine to read the pictures. Hopefully their machine will be able to read the memory card and then you can have them copy your pictures to a CD/DVD. After this is done then you would be able to reformat the card and clear the error. If the card still does not read or work then it seems you will need to look into a service that does data recovery.
Good Luck,
Paul
Jul 01, 2011 • Cameras
1helpful
All of sudden after using camara for 7 months, it says card not formatted. We have 800 pictures on card and finally got frustrated and said re-format. Then, says cannot read card and to insert a correct...
I would first try reading the card by inserting it in a PC connected card reader to see if it will recognize the card. If you can read the card via the PC, back off the pictures. Once you back them off, attempt to reformat the card. If you can reformat the card you should be able to use it again in the camera. Insert the card into the camera and check to make sure the card can be recognized and to check the camera does not have a problem reading the card. If it cannot be read, you will have to have the camera serviced. It should still be under some warrantee.
If the card cannot be read by either the PC or the camera, the card has been damaged and needs to be replaced.
Our polaroid digital camera i737 displays "Card Locked". We have checked the obvious in that the SD card is not locked and tried the card in other cameras and it works. Suggestions?
Somehow the card is set to read only in the software in the Polaroid. You will need to download the pictures onto a PC and then try to reformat the card in the camera. If that fails reformat on a PC and then try formatting in the camera. If that fails you will have to get another card.
I have a 2 gig card that won't let you use that amount of room
Reformat he frame's internal memory.
1. Click on the "Macintosh HD" icon.
2. Click on "Applications".
3. Click on "Utilities".
4. Click on "Disk Utility".
5. "Kodak" drive should be in the list showing a white drive icon
6. Click that icon and select “Erase”.
7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below.
8. Try to copy the files to the re-formatted internal memory of the frame.
When i take a picture it wont save on the memory card? and the pictures saved on the camera wont copy to memory card either. everytime i try and copy the pictures it says no file to copy.
THe memory card is either to large for the camera, or needs to be formatted. Put the memory card in a laptop or other card reader and inspect what is on it; save the contents and then reformat the card for the camera by running format.
While copying pictures into my computer i formatted the card  affter copying the pictures & since then my nikon camera is saying memory card cannot be used
Always format memory cards from the camera, never the computer. The camera has an operating system that may not be able to read your computer's system. Try reformatting the card in your camera, See if that works.
Camera not properly reading memory card
The problem stems from deleting some of the images from the PC. You need to copy all the files onto the PC, and delete all of them from the card on the camera. Then reformat the card on the camera. Then take 1 picture on the camera.
After you have just 1 new photo on the card, try copying the older files back onto the card in the same directory as the 1 new photo. This may work.
If it doesn't work, the problem may be with missing hidden thumbnail files. In that case you may not be able to get the photos to display on the camera again.
1helpful
"incompatible jpeg image" message
Unfortunately Windows in particular can mess with the contents of the card just by reading it - it creates a thumbnails file on the card without asking etc etc.
It shouldn't mess with the actual pictures unless you have rotated them or perhaps removed the card without safely removing the hardware first.
Try reformatting the card on the camera and you should be good to go from there.
1helpful
2answers
Pictures do not show up on SD card
Have you successfully used this card in this camera before? If not, you may have a new card that is too large for this camera to use, not all cameras can use the newer large cards. If you have successfully used this card in the camera before, you need to reformat it IN THE CAMERA to make sure the file structure is correct for this camera. When you reformat a card all the data on the card is lost, so be sure you have copies of all the photos backed up on your computer before you reformat the card!
Top Sony Cameras Experts
W.L.
john h
Ngoro
Are you a Sony Camera Expert? Answer questions, earn points and help others
