Question about American Standard Plumbing
American Standard Edgewater Single handle pull out faucet. Hot water pressure trickles.
First faucet pressure was low both hot and cold. Then next day water pressure almost nil. After following steps to fix the problem couldnt get working. Company sent second one. Water pressure good on cold but hot water pressure next to nothing. We checked the areator it was fine. Flushed the pipes. Water supply is fine. My father removed cartridge. Ran the water. Cold water came out where the cartridge was taken out. But the hot trickled out. He turned off water and disconnected hoses blew are through. Air would go through the side where the cold water would go through. Tried on the hose for the hot.Barely any air on that side. So seems like the problem is not in the hoses???
Posted by Teresa Wilson on
artie g
  • 873 Answers
Mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
Posted on Sep 27, 2018
1 Related Answer
emissionwiz
Marvin
  • 85239 Answers
SOURCE: no hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Posted on Feb 02, 2012
No hot water pressure
Feb 02, 2012 | American Standard Plumbing
Have single handle faucet with pull out sprayer. Whe I turn handle toward the hot side the water pressure drops almost to a trickle. Turn to cold and it is ok. What is problem and how to fix Thanks
Check under the sink at the valves that the hot and cold water lines are connected to. See if the hot water one is turned on all the way.
JOe
Mar 02, 2011 | Blanco Plumbing
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
American Standard Cadet 2-handle tub & shower set-Model#3275 - low pressure output
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
Oct 24, 2008 | American Standard Colony 3275.505 099...
Plumbing Logo
396 people viewed this question
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
