Question about Arcsoft Computers & Internet
Windows 10. Cannot connect to internet! Connection fine. Trying to upload to YouTube. Arcsoft Showbiz
Posted by Jim Eastwood on
rdarell
    New Friend:
  • 22 Answers
  1. Open a Windows command prompt
  2. Type ipconfig/flushdns and press Enter.
  3. Type ipconfig /registerdns and press Enter.
  4. Type ipconfig /release and press Enter.
  5. Type ipconfig /renew and press Enter.
  6. Type netsh winsock reset and press Enter.
  7. Restart your computer.
Open command prompt with admin privileges, right click command prompt choose open as admin
Posted on Sep 30, 2018
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
megax01
megax01
  • 50 Answers
SOURCE: my zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
Posted on Jan 19, 2009
kakee
Michael Galve
  • 1269 Answers
SOURCE: Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Posted on Jun 09, 2009
SOURCE: Trying to find drivers for MobiDTV pro -Arcsoft
here. http://www.jason-saggers.com/?page_id=109
Posted on Feb 21, 2010
AYYASAMY KASIRAJAN
  • 523 Answers
SOURCE: N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Posted on Apr 13, 2010
Hello, I have a problem with the arcsoft showbiz
You said you transfer a VHS to DVD, so does it mean you get videos from analog camcorders to make a DVD? For those camcorders, you need special line to connect with computer and your computer also need analog video capture card. If you mean your videos on DVD discs have troubles, maybe you should know what is your disc type. Rewritable ones are OK to be edited with ShowBiz, and once-only ones are not, they should be fanalized in DVD camcorder first. If it's the program's problem, go to www.arcsoft.com to ask their proffessionals. There's a new ShowBiz 5 you can have a try.
Aug 24, 2011 | Arcsoft ShowBiz® DVD 2 Full Version for PC
Reinstalling arcsoft showbiz2 on to computer and it is asking for an activation code ??? Have used it countless times and now can't access it without this code
1. Launch ShowBiz.
2. Under the Help menu select Online Product Registration. Your web browser will launch and display the registration form.
3. You can find your serial number in the Serial Number field of the registration form. Or you can fill out the registration form and submit it. You will need to be connected to the internet to submit the form online.
Jun 21, 2011 | Arcsoft ShowBiz DVD 2 (3265)
I have showbiz dvd2 and am trying to convert vhs to dvd. The process is straight forward however, while the audio is fine, the video is jumpy, not a smooth flowing picture. I have changed bit rates etc but...
we don't have a fix for this although i'm sure it will be along the same lines.
Contact Arcsoft direct.
The quick fix is to use other software to capture and then import the video into Arcsoft to edit, burn to DVD etc.
Debut capture software. It is free and good.
http://www.nchsoftware.com/capture/index.html
Scroll down to near the bottom and download the "lite" version.
when you open, click on "device" at the top to open the capture window.
and try to watch this link for a short tuturial on showbiz 2 movie making...
http://www.youtube.com/watch?v=cnBLwv2aRD4&feature=related
Jun 05, 2011 | Arcsoft ShowBiz DVD 2 (3265)
How to edit picture?
ArcSoft ShowBiz is a movie editing/ burning tool. It is not designed to edit pictures.
Mar 02, 2011 | Arcsoft ShowBiz DVD 2 (3265)
I'm trying to create a dvd in Arcsoft Showbiz. When I add an AVI file, it is reading it as a sound file, so no video shows, only sound plays. I've never had this problem before and have burnt many other...
I think you should use Leawo DVD Creator. Leawo DVD Creator is an easy and fast DVD creator for any video to DVD creation. It can create DVD from popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, XviD, 3GP, etc., apply DVD menu from various stylish presets in customized background and music.
And the trouble you meet will never appear in this software. You can use it easy.
Feb 27, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Wew
The problem with all the Arc soft Showbiz usually occurs and they had come with the new patches, that must be installed to solve the issue..
You can download all the patches from the following link,
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.53_2.2.2.69_update_e.exe
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.69_2.2.2.81_update_e.exe
http://www.arcsoft.com/downloads/showbiz2/arcsoft/showbizdvd_2.2.2.81_2.2.2.107_update_all.exe
After insallting, your issue should be solved
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Arcsoft ShowBiz DVD 2 (3265)
Having trouble uploading files to youtube. Losing connection during upload.
you can download the you tube up loader software from this link :
http://dvdvideosoft.com/download/FreeYouTubeUploader.exe
after you are done with this you can see how the software works from this link:
http://www.dvdvideosoft.com/guides/dvd/upload-video-to-YouTube.htm
Mar 12, 2010 | Arcsoft MediaImpression for PC
Computers & Internet Logo
286 people viewed this question
Top Arcsoft Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
