Radio Communications Logo
Question about Radio Communications
Whats the passkey Bluetooth code for Zoey 2.4 3G
Posted by allison on
5 Related Answers
NastyNataly
Nataly Roberts
  • 30 Answers
SOURCE: need passkey code for bluetooth
The default is 0000 (that's 4 zeros)
Posted on Dec 30, 2008
Anonymous
  • 139 Answers
SOURCE: Need Bluetooth passkey
a passkey is just a normal inserted between two bluetooth devices to connect them securely.
Let it four times 0000 as your passkey
Posted on Feb 17, 2009
Anonymous
  • 405 Answers
SOURCE: forgot bluetooth password
Passkey is "0000"
Posted on Feb 19, 2009
Anonymous
  • 7 Answers
SOURCE: need passkey code for motorola h550 bluetooth
0000
Posted on Sep 22, 2009
k24674
  • 8092 Answers
SOURCE: what is the bluetooth passkey code?
When you are pairing your TOMTOM with a BlueTooth-enabled cellular phone, your TomTom will ask you to enter "0000" when the phone asks for a pin. In order not to have to enter the pass code every time you want to connect to the phone, declare the TomTom as a trusted device.
When you are pairing the two make sure that the phone is "visible for xxxx minutes" or "always visible".
Posted on Jan 25, 2010
How can I reset my bluetooth password to my Dixon DN3238M3 receiver?
Where do I input the Bluetooth Passkey
  1. Touch Apps . Touch Settings.
  2. Turn Bluetooth on . ...
  3. Touch Bluetooth to scan for available Bluetooth devices (make sure your device is in pairing mode).
  4. Touch the Bluetooth device to select it.
  5. Enter the passkey or pair code: 0000 or 1234.
  6. Touch the device name again to connect to it if it doesn't connect automatically.
https://forums.republicwireless.com/t/where-do-i-input-the-bluetooth-passkey/3788/2
What is the code for rapoo mouse
How do I find the pin for my Bluetooth?
When a list of detected devices appears on the display of the BLUETOOTH device, select "SRS-X55." If a passkey* is required on the display of the BLUETOOTH device, enter "0000." A passkey may be called "Passcode", "PIN code", "PIN number" or "Password."
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
What is a passkey code
With most bluetooth devices on the market today, the default pass key code that comes programmed with the device is "0000" (four zeros).
1helpful
What does error code 80010009 for the crysis bluetooth 2 mean
Incorrect passkey for Bluetooth device. Description: Entered wrong passkey for the Bluetooth device when trying to pair it with the Playstation 3.
Source: http://us.playstation.com/support/answer/index.htm?a_id=939
Lost passkey for dell d600 bluetooth
hi
  1. Step 1 Checkyour device for a sticker with the passkey printed on it. Typicallyheadsets and car stereos have the passkey printed on a small stickerattached at the rear of the device.
  2. Step 2 Lookin your device's instruction book to see if the passkey is writteninside. Each device has a unique passkey, so the passkey for yourdevice will typically be printed on a sticker or inserted into yourinstruction book, as opposed to in the directions themselves.
  3. Step 3 Check the Bluetooth menu for your device. Cell phonesand computers often have their passkeys within the Bluetooth menu. Lookfor the "Pairing Code" or "Passkey" option. Some laptop computersgenerate a random code each time you need it, so you may have a optionfor this task.
  4. Step 4 Checkin forums for your particular device to see if someone has posted thepasskey. Typically a search for your device and "Pairing Code" willbring up information regarding the code or where you might successfullyfind it.
  5. Step 5 Call customer servicemag-glass_10x10.giffor your device if you can't find the passkey printed on the device, inthe instruction book or in the menu. Customer service should be able toeither tell you the passkey for your device or give you detailedinstructions on how to find it.
2helpful
2answers
I do not understand what this passkey for bluetooth connection is. I don't have a bluetooth headset but im trying to pair my samsung highlight with a samsung messenger 2. I have already tried the four...
Step 1
Check your device for a sticker with the passkey printed on it. Typically headsets and car stereos have the passkey printed on a small sticker attached at the rear of the device.
  • Step 2 Look in your device's instruction book to see if the passkey is written inside. Each device has a unique passkey, so the passkey for your device will typically be printed on a sticker or inserted into your instruction book, as opposed to in the directions themselves.
  • Step 3 Check the Bluetooth menu for your device. Cell phones and computers often have their passkeys within the Bluetooth menu. Look for the "Pairing Code" or "Passkey" option. Some laptop computers generate a random code each time you need it, so you may have a option for this task.
  • Step 4 Check in forums for your particular device to see if someone has posted the passkey. Typically a search for your device and "Pairing Code" will bring up information regarding the code or where you might successfully find it.
  • Step 5 Call customer servicemag-glass_10x10.gif for your device if you can't find the passkey printed on the device, in the instruction book or in the menu. Customer service should be able to either tell you the passkey for your device or give you detailed instructions on how to find it.
  • 0helpful
    What is the bluetooth passkey code?
    1helpful
    2answers
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Tom Chichester
    Are you a Radio Communication Expert? Answer questions, earn points and help others
