Question about HP Tablets & eReaders
How do i factory reset HP / Compaq ElitePad Tablets 900 G1 Tablet P windows 10 without activation key i dont have a system restore image either
Posted by Jay BGrimm on
Andrew Taylor
    Top Expert:
  • HP Master
  • 34,121 Answers
You can use a key reader software program to read the key, but without the Windows 10 installation image you are stuck. They are usually on a hidden partition on the hard drive? If not, because it is a Compaq and has a custom Windows image, you would have to buy a replacement from Compaq.
Number one tip, have computers made for you and buy a standard OEM Windows Operating System.
The fact it is a tablet makes things a lot easier, you just do a hard reset as described here.
Hard Reset HP ElitePad 900 G1
These videos suggest that the Operating System is Android and not Windows so you don't need an activation key.
compaq elitepad tablets 900 g1 tablet hard reset Google Search
Posted on Sep 23, 2018
5 Related Answers
rcw1962
Roy
  • 2571 Answers
SOURCE: Is there a restore to factory image key sequence
Had a good look around for you, the information you need is on a support page, but you need to register your product.
With it being a professional product, they will probably charge alot for a restore disc/additional support
Posted on Jul 20, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: how to find my Hp Compaq tc 1000 tablet pc Os product key again
Hello
The best thing to do here is contact product support at HP, they can get your key for you, in fact they are the only ones that can. Here is a link to the HP support site.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=307008&lang=en&cc=us
Use the "Contact HP" link at the top left of the product support page..
Posted on Nov 04, 2011
TechyDrood
Justin
  • 2072 Answers
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
Posted on Nov 27, 2012
amisset
  • 224 Answers
SOURCE: How do I factory reset my celcus tablet without
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Here you find how to reset for different brands' of android.
Posted on Dec 09, 2014
ray gallant
  • 69264 Answers
SOURCE: Is there a way to do a factory reset on a southern telecom V7 tablet without accessing the screen?
have you tried removing the battery then replacing it
Posted on Jan 10, 2015
How do I factory reset a Ematic EGQ327M tablet without a password
FixYa
Ematic Eb104 eBook Reader
Question about Ematic Eb104 eBook Reader
ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
by sharhonda cox on Jan 8, 2014
Add Comment · Flag · Share
April Argo
Level 1 New Friend · Contributor
Andrew Jones answer was correct...
Helpful 0 Not Helpful ·Add Comment ·Flag
M Asish
Level 2 MVP · Expert
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Aug 04, 2018 | Tablets & eReaders
Non of the apps on my acer tablet are working , I have gone through all of the updates and restarted the tablet multiple times
Might want to contact them -https://www.acer.com/ac/en/US/content/support
If you don't mind losing all you have saved on it you can try a factory restore- It will delete everything!
Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen.
Jul 12, 2018 | Acer Tablets & eReaders
My tablet won't go past the icon for android
Is this android tablet 4.4 and above?
If yes, try hard reset.
1. power off tablet
2. press and hold power button and (home button) or volume+
3. release only the power button when you see it power on, keep pressing and holding the volume + or (home button)
4. You should see an android recovery menu
5. Select :Wipe data factory reset" with volume - key go down selection. then press power button once to Enter
6. Select : "Delete all user data" with volume - key. then press Power button as enter.
7. Will restore to factory data and "reboot system now"
8. Press "power button" once and it will reboot.
9. system will restart and load again, this time whait a while on "Android" boot logo and it will finish restoring.
10. all done.
note: use volume + or also try Volume - with power key or use the home button should be another button that looks like the power key.
hope this works for you. reply with your comments.
Feb 05, 2018 | Tablets & eReaders
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
How to reinstall os on coby 7" tablet?
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
Jun 12, 2014 | Coby Kyros MID80244G Tablet
My V55 android tablet is locked and i dont know the email
You can try to do factory reset on your tablet so that your tablet would get unlock. 1.Press the power-key and volume-down key at the same time until the phone get into the recovery mode.
2.Press home key to get into next interface.
3.There will be four choices: reboot system now;apply update from external storage ;wipe data/factory reset;wipe cache partition.
4.Use "Vol+" and "Vol-" to move the cursor up and down.
5.press power key to select wipe data/factory reset.
Jan 22, 2013 | ZTE Optik / V55 CDMA Tablet
Everytime i turn on my coby kyros a message comes up and says .... the process android.process.acore has stopped unexpectly.Please try again............ Ive tried reseting it and letting it die and then...
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Apr 07, 2011 | Coby Kyros 716829701508 Tablet PC
Operating system,xp tablet edtion
I know it might not be...moral...but there are OEM ISO versions of XP Tablet Edition out there on bitorrent sites. Now I DO NOT CONDONE downloading one and using the Key supplied in the torrent, I simply am telling you a method to get your hands on an OEM Restore Disc from HP.
Your COA is located under your battery on your tablet. Use that COA in conjunction with the downloaded ISO to remain 100% legal.
May 30, 2009 | Compaq tc1000 Tablet PC
Replace hard drive but can't load tablet operating system
Do you have the system restore disks for your tablet? Once you have restored windows then you need to use the second disk to load all the drivers
Mar 23, 2009 | Compaq tc4200 Tablet PC
TC1100 onscreen keyboard.
Use a USB keyboard and do a system restore.
Use a USB keyboard to access HP.com and search for a download there.
Use a USB keyboard to backup, reformat, reinstall factory image.Takes longer, but probably best overall fix, HDD may have a few bad sectors and format will fix or avoid them. May be a great time for a 7200 RPM drive and some more RAM! 2Gb RAM and a high speed drive will breathe a bunch of life into a great tablet like the tc1100.
Feb 03, 2008 | Compaq tc1100 Tablet PC
Tablets & eReaders Logo
171 people viewed this question
Top HP Tablets & eReaders Experts
Lawrence Oravetz
Marvin
Marvin
matt
matt
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
