Question about GE Washing Machines
GTW330SK0WW GE WASHER 2 YEARS OLD MAKES A METAL TO METAL SCREECHING SOUND DURING THE AGITATION CYCLE. I HAVE HAD IT APART AND THE BASKET IS HANGING PROPERLY.
Posted by Richard Haywood on
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Posted on Jan 13, 2007
Anonymous
  • 291 Answers
SOURCE: my GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Posted on Nov 08, 2007
duby1990
Justin Duby
  • 370 Answers
SOURCE: Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Posted on Jan 28, 2009
Anonymous
  • 1066 Answers
SOURCE: Motor makes a clunking sound (Shuts on/off)during agitation cycle
sounds like you need a new motor/transmission coupling.
Posted on Mar 11, 2009
Anonymous
  • 225 Answers
SOURCE: loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
Posted on May 02, 2009
My Maytag PAV2200AWW Washing Machine makes a noise like grinding or metal-metal contact during the agitate cycle. How can I fix it?
The sounds of 'metal grinding/banging" begs the question of whether or not its even safe? If you hear that sound all the time or as you say ONLY during the agitation cycle suggests that you be able to service the tub/motor mounts in the underneath chass--which is a heavy-duty technician job. A Maytag technician has the tools you need. Or the obvious...get another one from a friend who is upgrading to a new washer and hands it down to you for a little change.
Dec 12, 2015 | Maytag Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
GE top loading wash machine makes noise during agitation cycle...
look in your basket of washer see if you see anything stuck in the hole ok
Oct 20, 2017 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Majic Chef 400
HI i think you have a transmission problem. expensive to fix
Sep 07, 2008 | GE WBSR3140DW Top Load Washer
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
