Question about Furniture
How do I get the Perego seat from the reclined position
Posted by Becky Herzberg on
5 Related Answers
NewMerlin
SOURCE: front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Posted on Jul 28, 2008
Anonymous
  • 566 Answers
SOURCE: drivers side seat not working properly
hi this sounds like the coiled spring that is enclosed behind the cover where the recline lever is it has either broken or the pin it locates on has snapped or spring has for some reason slipped its fastening ? try removing cover and investigate the spring and its locator points
Posted on Dec 29, 2008
Anonymous
SOURCE: 2001 Nissan Altima - Seat Back stuck in the recline position.
where is the overload protection circuit for power seat of nissan altima 2001 , the seat does not move back and front let me know if i could do the seat move
Posted on Feb 10, 2009
jcj4820
  • 19 Answers
SOURCE: camry power driver seat motor won't return from recline position
it has three septet motors with gears
if one is bad you will replace it
Posted on Feb 24, 2009
Anonymous
  • 321 Answers
SOURCE: the reclining lever for my has broke off cant
well lets not start with visegips .
the lever needs to be removed by removing the screw and removing the lever.
go to the dealer to get the new lever and put it on.
Posted on Jun 12, 2009
How do i recline the Peg perego Prima Papa high chair?
Lift up on the handle in the middle on the seat back. There are usually 4 stops along the way from upright to recline.
Feb 22, 2013 | Peg Perego Prima Pappa High Chair
HONDA ACCORD Seats Front Assembly Recliner went down and won't go up
I wouldn't ruin anything by trying things yourself
I would have a dealer check it out
The dealer I used in the past, has a seat specialist come
in on Wed only, around 5:30 after the service bays close
& one service writer hangs out until that person fixes a
couple vehicles seat issues
Jun 12, 2012 | 1995 Honda Accord
How do you get it to recline in the laying position??
Hi check this video out it will show you how to recline the stroller.
http://www.Babygizmo.com.
I hope this helps you? Please leave feedback if it does, Thank you. Regards Marie
Sep 22, 2010 | Peg Perego Pliko Matic Umbrella Stroller
Attaching Peg Perego Car Seat
It's hard to describe with words. I would suggest you to watch video reviews on how you can attach your car seat. Also you can get help from your manual book which you got while purchasing the stroller. Hope that will help. Visit here for more: Best Twin Pram For The Money in 2017 Tested and Reviewed
Nov 24, 2017 | Baby Jogger Onyx 2010 City Select Stroller
PEG PEREGO 2006 P3. HOW TO CONNECT AND INSTALL CAR SEAT TO STROLLER?
Recline the stroller flat,under the seat pad there should be 2 pegs that pull out the carseat will click on these,good luck.
Aug 18, 2009 | Peg Perego P3 Stroller 2006 Rubino...
I have a peg perego viaggio sip and how do I remove the toddler seat?
You do'nt have to take the seat of it just needs to be reclined flat to fit a carseat.
Jul 28, 2009 | Peg Perego Pliko Hood Stroller
Front seat stays in the reclined postion..
Jul 22, 2008 | 2000 Ford Focus
Would you please provide me with instructions for reclining the seats on my Peg Perego triplette stroller?
PLEASE GIVE ME YOU MAKE AND MODEL SO I CAN DO SO, SO I CAN DIRECT YOU THE RIGHT WAY STEP BY STEP. THANKS
May 01, 2008 | Peg Perego Duette MT Newport Twin Stroller
Reclining back problem
I'm having the same problem. It's very frustrating.
Dec 05, 2007 | Peg Perego Aria OH - Free Style Mint...
Furniture Logo
108 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
